07-11-2012, 11:54 AM | #1 |
axle saddles
Where do you guys find them? Trying to get a few sets for the trailing arm style. playing the musical rear axle game on a few trucks.
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726 66 fleet lwb- In process 64 k10 10inch lift 38.5's- In process 92k1500 400hp on 38.5-parts truck now 8( |
07-11-2012, 11:59 AM | #2 |
Newbee
Re: axle saddles
Try CPP, That's where I got mine for my 69.
07-11-2012, 12:54 PM | #3 | |
It's Better With Nitro
Re: axle saddles
Search by "rear axle saddle"
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
07-11-2012, 07:04 PM | #4 |
Re: axle saddles
If you are talking 60-72 coil spring 1/2 ton, then I think this kit from CPP is the way to go. It uses the stock frame mount for the new long panhard bar which connects to the RH axle saddle.
http://www.classicperform.com/Store/...k/6072DRCK.htm |
07-11-2012, 07:10 PM | #5 |
Re: axle saddles
If you really just want the saddles, those are here;
http://www.classicperform.com/Store/...ck/6072RAS.htm |
07-12-2012, 12:13 AM | #6 |
Re: axle saddles
awesome.. thanks for the input!!
