Old 07-11-2012, 02:27 PM   #1
lousblown55chevy
need info on burb seats
will the rear seat from a blazer work in the middle of a burb , are the mounts in the floor different from a burb with 3 seats compared to one with 2 seats
lousblown55chevy is offline   Reply With Quote
Old 07-11-2012, 02:49 PM   #2
vectorit
What?
vectorit's Avatar
Re: need info on burb seats
The seat itself will, but the brackets will not.
You will have to find 67-72 burb brackets to make it work right.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-12-2012, 02:37 AM   #3
DBear
DBear's Avatar
Chris....do u have a pic of the correct Burb bracket?
DBear is offline   Reply With Quote
Old 07-30-2012, 02:21 AM   #4
70GreenBurb
70GreenBurb's Avatar
I think there are two versions of the middle seat. I think the one that goes with a third row see is a basically a third row seat installed in the center position. My burb was ordered with second row seat and it is wider than the center seat for a 3 row option. There isn't room by the passenger door to get through to a 3rd seat. It also has three rear legs.
1970 Custom 10 Suburban- 350/700R4 w/3.07 Gears
1961 Shasta trailer
2001 Tacoma Reg Cab (Mini Taco)
Photobucket pictures- http://m1254.photobucket.com/albumlist/vintage6170
70GreenBurb is offline   Reply With Quote
Old 07-30-2012, 09:51 AM   #5
nate_g_2003
nate_g_2003's Avatar
This is correct. If you have a truck optioned for a 3rd row, the 2nd row isn't as wide as the 1st row (assuming you have a 1st row bench.) If you are only optioned for a 2nd row, that seat spans the entire width of the interior.
My suburban is optioned for the center and rear seats, and aside from the mounting bases, they look identical (and IMO, identical to a Blazer rear seat.)
Just throwing that out there, hope it helps. If need be, I can try and grab some pictures of my center and rear seat mounting after work.
-Nathan-
1972 GMC K2500 Suburban "The Project"
2013 GMC Sierra 1500 SLT Z71 "The Daily Driver"
2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD
1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD
2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD
nate_g_2003 is offline   Reply With Quote
