Old 07-11-2012, 04:35 PM   #1
jsdoyle
jsdoyle's Avatar
Deluxe Heater control lever needed
I pulled the deluxe heater control assembly from a 65 at a salvage yard. It cleaned up real nice but the center lever is broken off on the front.
It's the lever that controls the fan switch and air.
I was wondering if anyone had a spare laying around that they wouldn't mind parting with? LMC sells them as a set and I don't need the other two levers.
jsdoyle is offline   Reply With Quote
Old 07-11-2012, 04:39 PM   #2
1963c-10
1963c-10's Avatar
Re: Deluxe Heater control lever needed
I have an extra OEM one. The repops are actually better though as they are stamped steel where the OEM ones are cast pot metal. This is one of the few repop items that I do recommend.
1964 Short bed trailer
Old 07-11-2012, 05:31 PM   #3
jsdoyle
jsdoyle's Avatar
So you'd recommend I purchase the steel ones at LMC? I see what you mean. The two that are working are pretty flimsy. I can see them breaking off about the time I get it all put together.
The three lever set is 45 bucks. Anyone know of a less expensive source?
Thanks!
