TH350/NP205 Adapter Bearing
I'm swapping my NP203 for a NP205 out of a '72 Blazer. The adapter has the support bearing in it which is trashed. Anyone know the part number for it? Digging around online, I can't seem to find anything. Instead of replacing it, can I replace the drive coupler with a later straight unit and just leave out the bearing? Thanks for the info.
Mike |
Re: TH350/NP205 Adapter Bearing
Yes, you can delete the bearing. I tried to find that bearing and coupler one time and it is discontinued. The coupler was sloppy, so I went with the non bearing coupler and everything is a-ok.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
I think 1970/71 was the first year for the non bearing coupler.
I got mine at a place called 4xheaven in NY. Call em up.
Thank you for the information. I appreciate it.
Chief....please use search, your info was discussed here:
http://67-72chevytrucks.com/vboard/s...hlight=adapter
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
I have a January built 1972 K20 which still has the bearing.
For those who wish to keep the bearing in place the part # is MRC 209S. Here are the rest of the part numbers for the square O ring, 2 inner seals and t case to adapter seal (mandatory!! do not seal with RTV) O ring : TK30046 Seals : 471424 T/C seal: TK10516, QU50450 |
![]() Join Date: Mar 2003
Make sure you pack the spline coupler with grease before installing--both sides
Pack? I put a finger full of HD grease on each side, should I pack it full?
Also forgot to mention there is also an O ring on the T/C input shaft that slides into the end of the coupler. No part number or listing but got one at an old school auto parts that had the orange Dorman boxes and i just matched them up. |
Well, you don't have to pack it solid, but there should be a decent amount
