Old 07-15-2012, 11:23 AM   #1
Ta2Don
Ta2Don's Avatar
Donz '65 SWB Stepper Budget Build...
Hello everyone, found this forum when I began searching for an early 60's truck to add to the family. My current DD is a 90 Silverado Short Fleetside and I 've always loved the 60's GM trucks, owned a '61 GMC Short Fleetside in the mid 80's and regretted selling it... Finally decided it was time to return to my generation, I was built in 60 so...
In March, I considered buying a 60 apache off of a friend, fellow Tattoo Artist, but after an in-depth inspection along with research completed on this forum and price considerations, I decided to pass and found my 65 SWB Step side through another acquaintance. Truck had previously been gone over, PO had 350 and Turbo 350 tranny installed, '91 Burb buckets, and used a HIDEOUS black with rainbow metal flake paint throughout engine bay and various interior accents. Purchased the c10, minus engine, in April and immediately began the process of making the truck mine.
Been hemming and hawing over starting this thread, Thanks to Icewatercarter for getting me motivated to finally do this. I've posted replies and pics on the "What Did You Do To Your Truck Today" thread, and have finally stepped over the edge (so to speak)...
Over the course of the coming week I plan on bring this thread up to date, here are pics of the truck the day it was delivered...
Ta2Don is offline   Reply With Quote
Old 07-15-2012, 12:34 PM   #2
Ta2Don
Ta2Don's Avatar
Re: Donz '65 SWB Stepper Budget Build...
This is the progress made after two days, The truck was delivered on a Saturday, I had to work all day. Sunday afternoon we started on the truck and this is the progress by Monday afternoon...
Old 07-15-2012, 12:39 PM   #3
Ta2Don
Ta2Don's Avatar
Plans are to do a Static Drop, swap to 5 Lugs with Disc/Drum Power Setup. Going to go SeaFoam Green with a base/clear and flatten out the clear.
Old 07-15-2012, 04:06 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
The truck looks to be clean and solid in the otherwise problem areas.
I like budget builds.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-15-2012, 05:02 PM   #5
Ta2Don
Ta2Don's Avatar
Gauge Pod done up with Whiteout Gauge package, Valve covers after adding the orange accents, Serpentine Belt Brackets, Water Pump and Pulleys
Old 07-15-2012, 05:15 PM   #6
Ta2Don
Ta2Don's Avatar
Not sure what happened, here are the pix
Old 04-19-2014, 10:45 AM   #7
dwlambert1701
What type of paint did you use on the valve covers. I really like that look.
dwlambert1701 is offline   Reply With Quote
Old 04-19-2014, 10:50 AM   #8
Ta2Don
Ta2Don's Avatar
Chevy Orange Engine Paint, not sure of brand... May be going a different route... PM Sent
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Old 07-15-2012, 05:16 PM   #9
Ta2Don
Ta2Don's Avatar
2 outta 3, here is the Gauge Pod
Old 07-15-2012, 05:17 PM   #10
Ta2Don
Ta2Don's Avatar
Guess I'm gonna wait for better Internet connection before I continue...
Old 07-15-2012, 08:16 PM   #11
icewatercarter
heck yeah man, looks real good. i like the gauges, gives me ideas...and motivation. been lazy(broke).
icewatercarter is offline   Reply With Quote
Old 07-15-2012, 08:23 PM   #12
Ta2Don
Ta2Don's Avatar
Thanks Rick
Old 07-15-2012, 09:35 PM   #13
Ta2Don
Ta2Don's Avatar
Me and my Help in the midst of dealing with a stubborn Radiator Support Mounting bolt, ended up cutting it off, Front sheet metal, sans fenders, on the ground, The Son playin' LOW RIDE ERRRR!!!!
Old 07-15-2012, 09:46 PM   #14
Ta2Don
Ta2Don's Avatar
After the '85 Crossmember installation...
My new used wheels...
After the dropped spindles installed and 1 coil cut from springs...
Old 02-16-2016, 07:40 PM   #15
ebaby35
Did your 85' bolt right in. I have a 62' just got a 85' suburban to swap it out with.
ebaby35 is offline   Reply With Quote
Old 02-16-2016, 10:02 PM   #16
Ta2Don
Ta2Don's Avatar
On the 65, I had to drill 2 holes and elongate 2, I also had to drill the frame for the Idler Arm, the '85 one mounts at a different angle from the '65
Not sure if there's much difference for the '62 frame, check the FAQ thread... lots of info out there.
Thanx for looking in...
DON
Proverbs 27:17
Old 02-16-2016, 11:37 PM   #17
TJ's Chevy
TJ's Chevy's Avatar
Awesome to see an update brotha!!!! Bed is looking Sweet!
Old 02-17-2016, 07:52 AM   #18
clemdaddy
clemdaddy's Avatar
Could you take a couple of measurements on the location of the hole in the spare tire fender mount. We bought a new fender and the hole wasn't there, guess it's generic for the long bed.
Thanks Don. No rush, just when you get time.
Woops! never mind bro... just saw on FB where Pete asked you the same thing. Geeez, I gotta learn how to keep up with this tech stuff.
Have a good one...
clemdaddy is offline   Reply With Quote
Old 07-15-2012, 09:58 PM   #19
Ta2Don
Ta2Don's Avatar
'70 Chevelle Rear Spring next to OEM Spring...
New springs installed...
in lieu of a BFH I borrowed a friend's Snap On 1/2" Electric Impact. After soaking spring bolts in penetrating oil for a week, still had to break out BFH to tap on trailing arms prior to motivating the bolts with the Snap On beast... Waiting on tires to arrive so I can get back to a rolling chassis, then time to mock up engine and front end, then bed to check out stance, thinking I'm still gonna need lowering blocks...
Old 07-15-2012, 10:09 PM   #20
Ta2Don
Ta2Don's Avatar
A pic of my '61 GMC... miss the old truck...
Old 06-14-2013, 09:40 PM   #21
LostMy65
LostMy65's Avatar
Have you posted this in my Nostalgia thread?
Old 06-15-2013, 12:23 AM   #22
Ta2Don
Ta2Don's Avatar
I have now!
DON
Proverbs 27:17
Old 07-16-2012, 10:21 PM   #23
icewatercarter
your making some serious progress. i dont understand the coilovers and springs though.youll be done in no time at this rate
Old 07-17-2012, 08:17 AM   #24
Ta2Don
Ta2Don's Avatar
I assume you are talking about the shocks, they need replacing, and I'm waiting to get back to a rolling chassis so I can put bed on to see how low the new springs settle with the bed weight. Gonna evaluate then on whether or not I need lowering blocks, then get proper shocks. Will post pic of stance this coming weekend...
Old 07-18-2012, 03:49 PM   #25
Ta2Don
Ta2Don's Avatar
Dropped the old pistons and rods, along with the new pistons, off at the machine shop... Once those are back I can get the engine buttoned up, now I gotta get motivated on the firewall...
65 swb, c10, step side, tattoo
