Question---No Limit/Porterbuilt
Either one of you know of a customer that is running the No Limit Rack & Pinion with the Porterbuilt arms and swaybar. It looks like the sway bar could inter-fear with the rack.
I am to far along to put in a aftermarket cross member and would really like to upgrade to R & P.
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler 1968 Chevy c10 shorty Stepper (Patina LS project) 1967 gmc custom Long Box (Farm Truck Project) |
Happy to be here
![]() Join Date: Mar 2000
Re: Question---No Limit/Porterbuilt
I don't know if it will work but I bet Rob does. Give him a call and resolve your concerns...Then report back so we know too
![]() Join Date: Jul 2010
I don't know of anyone who has done this. Our rack/tie rod comes in under the steering arms, so you may want to contact Nate to see where his sway bar fits.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
#4 | |
We have a couple customers running Robs rack conversion with our "1inch Forward Control Arms" as well. Good combination. ![]() Posted via Mobile Device
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Thanks Rob/Nate for the info.
Nate, the longer swaybar links with the regular A-arms will also clear No limit R & P. Just wanted to confirm it wasn't just the 1" froward arms. Thanks again guy's
#6 | |
Thanks Nate,
i will call for some links once I confirm ordering the R & P Cheers..
Thanks, let us know how it works out. I think there are many others wanting to do the same thing.
#9 | |
I would like to mock it up with the longer links once I get them from Nate before fully installing it. Cheers,
Hey Rob,
just a heads up that I received the grade 8 bolts today. I have no other info to report but I will once my longer links arrive. Can't wait..... Cheers, Posted via Mobile Device
Just thought I would give an update.... I started to mock up the R&P the best I could to get an idea before drilling and grinding my fresh painted frame. I received longer links from Nate that look like they will help but it seems to still be tight. (keep in mind the R & P is only positioned in the center location and I cannot tighten the sway bar links because the new link bolts are 9/16 vs the original 1/2 so the washer ID is to small. Also noticed that the Allen cap screws for the r & p clamp needs to be countersunk otherwise they are to short (not a big deal)
More info: At full dump it seams that there is not enough clearance between link and r & p rod end coupler if the wheels were turned. : with wheels straight the length of r & p rods to spindle are 1" different ( 9.5" vs 10") is the r & p not in center position? Nate has identified that there are a few out there with this set up. If you are one of them we would love to see some install pics and hear some feedback..... Cheers, Posted via Mobile Device
I posted detailed pics of where I am at with the R & P mock up in my build thread so to not run the risk of doubling up on threads. If anyone has any advise please check it out.
