Old 07-16-2012, 12:30 PM   #1
AirSpeed
AirSpeed's Avatar
Is it safe to jack under the differential?
I see people do it all the time and have done it my self but always wondered if it could damage the axle using a floor jack under the differential to lift the rear (or front end if 4X4) It seems like it could damage or bend the rear axle housing, putting all that stress between the springs, could it do any damage?
AirSpeed is offline   Reply With Quote
Old 07-16-2012, 12:38 PM   #2
CC69Rat
CC69Rat's Avatar
Re: Is it safe to jack under the differential?
I do .. Have done it for years, I'd say so. I've never had any problems. I usually lay a rag on top of the jack to keep from scratching it but other than that, .. no problems.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 07-16-2012, 12:41 PM   #3
AirSpeed
AirSpeed's Avatar
Thanks, I don't know why but Im constantly waiting for the axle to fold in half one of these days.
Old 07-16-2012, 12:47 PM   #4
chevy72blu
chevy72blu's Avatar
Yep, that is the correct way to do it. It is the strongest point out back. The driveline shop I used to work at did it the same way.
I usually lift the pumpkin and lower the rear axles onto jack stands- very sturdy.
If picking up the pumpkin bends your axle, something very bad has already happened
chevy72blu is offline   Reply With Quote
Old 07-16-2012, 12:53 PM   #5
AirSpeed
AirSpeed's Avatar
Thanks, it's good to know! I've never had anything bad happen, just have strange phobia about doing so.
Old 07-16-2012, 01:04 PM   #6
VH Coachworks
VH Coachworks's Avatar
Airspeed: I am going a little off topic here, but noticed your tear drop trailer
in your picture, I love these tears, did you build it.or is it a restoration? Do you have any pictures you would like to share.
We are building a proto type, it is 5 x 10, most orginal ones were 4 x 8
WE might manufacture them if all goes well.
VH Coachworks is offline   Reply With Quote
Old 07-16-2012, 01:19 PM   #7
AirSpeed
AirSpeed's Avatar
I built it entirely from scratch and my own design. There are a lot of pics of it under construction on my Photobucket acc, clic the link below, I think they are on the last 5 or six pages. There's pics of lots of the strange things I make there.
I get offers on it all the time, at least once a month someone will knock on my door wanting to buy it or build one for them. I've turned down 8 grand, one woman offered me $14.000 delivered to Florida, I almost did it but I hadn't got to use it yet. It only cost about $1,500 to build so if you could build them fast enough you could make some money. Its got almost everything in it, queen sized bed, pull out sink with 20 gallons of on demand water, pull out stove/oven, fridge, fold down tv/DVD, XM, CD, solar power. It's so lite you can't even feel it behind the truck. It's been a lot of fun, we use all the time in the summer. Mine is 5X12'
Old 07-16-2012, 01:43 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by AirSpeed View Post
I built it entirely from scratch and my own design. .......... It only cost about $1,500 to build so if you could build them fast enough you could make some money...........Posted via Mobile Device
$1,500 to build and $15,000 in labor.
Man, what are you, a design engineer, fabricator, carpenter and artist all in one?
Great work on that trailer. I have some questions and a comment.. I noticed you first built it out of plywood. How did you do the metal fabrication for the outer covering? Did you do it all yourself?
Re. the driveshaft: The drive shaft part of the drive train and iis one of the most abused parts of a truck. Imagine the pounding it gets when traveling on dirt roads or roads full of potholes. It will definitely hold up to a jack lift.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 07-16-2012, 02:11 PM   #9
AirSpeed
AirSpeed's Avatar
Great work on that trailer. I have some questions and a comment.. I noticed you first built it out of plywood. How did you do the metal fabrication for the outer covering? Did you do it .
it's built out of 3/4 plywood on the sides and floor, it has 1 1/2" furring strips on the interior, it's insulated and then I used 1/8th Luan door skins to sheet the inside. The roof I used 1/4 plywood so I could bend it. The exterior is sheeted with aluminum, the trim had to be be annealed in order to bend it around the door, hatch, roofline, it took a little practice to heat it to the proper temp but it went pretty fast. The aluminum sheet is held on only by the trim, it stays nice and flat against the plywood without glue. As for being an engineer, I should have! I certainly wouldn't have the trashed spine I live with every day! I'm lucky when it comes to making stuff like this, it's always come easy to me. I built a hang glider when I was nine and a submarine when I was 15. I built a ski boat at 18 that I used for ten years before I got rid of it. Yea, I'm a show off. Thanks!
Old 07-16-2012, 01:25 PM   #10
AirSpeed
AirSpeed's Avatar
[QUOTE=VH Coachworks;5489032]Airspeed: I am going a little off topic here, but noticed your tear drop trailer
It took about two months working an hour or two a day when i had time and my back wasnt out. I could have probably done it in a week if I had worked full time on it. Thanks! Aaron
Heres a couple of pics
Old 07-16-2012, 01:46 PM   #11
VH Coachworks
You did a very nice job on the tear, love the design, everything flows nicely.
Thanks for the picture.
Old 07-16-2012, 01:18 PM   #12
LEEVON
Moderator
LEEVON's Avatar
I lift under the pumpkin as well, however I have noticed that some diff covers have a slight lip that will be bent and can cause leaks so I've gotten more careful.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 07-16-2012, 03:31 PM   #13
Billett
Billett's Avatar
Seriously. That trailer is awesome!
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 07-16-2012, 03:51 PM   #14
AirSpeed
AirSpeed's Avatar
Thank you! I've been designing a new one for some time now, it's going to have a very similar profile but the roof is going to pop up, my present trailer is about 4' high inside, I'd like to get the roof on the next one to raise up to give me 6' that way I can build in some collapsible benches and a table inside for camping later in the year, when it starts getting cold, that way the wife and I can hang out inside, eat, play games with my grand kids and just stay dry and warm. Of course who knows when I will get started. Thanks again!
Old 07-16-2012, 03:45 PM   #15
67chevemall
67chevemall's Avatar
I always put some soft pine on the jack first so it doesn't bend the lip on the pumpkin which can cause a small drip leak until you change the rear oil again.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 07-16-2012, 03:56 PM   #16
Billett
Billett's Avatar
I'd love to design something like that. I'm sure I could do it, although I doubt it would turn out as nice as yours. Unfortunately the future Mrs. Billett is not a fan of camping... Although if I put AC in it she might want to come to shows more often haha
Will
2024 Toyota Sienna
Old 07-16-2012, 05:16 PM   #17
yuccales
yuccales's Avatar
That trailer looks GREAT! Nice wheels.
yuccales is online now   Reply With Quote
Old 07-16-2012, 06:03 PM   #18
The trailer is nice,but got any pics of your jack under the pumpkin?
Old 07-16-2012, 07:03 PM   #19
AirSpeed
AirSpeed's Avatar
Good one! I'll set up a couple of pics! I did just get a shiny new aluminum "racing jack"! You know how fast a racing jack will make your truck go!
Old 07-16-2012, 09:54 PM   #20
I don't know,but I think it makes them go "up" a lot faster,right? BTW,nice work on the trailer.
Old 07-16-2012, 11:18 PM   #21
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Great looking traier.I've been wanting to buuild one for a while though in a "Woody" finish.You must be quite good at carpentry to be able to pull off the curved drawers and such.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
