Old 07-16-2012, 10:53 PM   #1
markreed
What engine is this?
Just bought a "new" truck. '64 GMC 1000 series.
I have been looking over the engine, and I cannot seem to figure out what it is. I am relatively new to older modeled engines. My first thoughts were that is was a 350, ive been told that is the easiest swap to make. Also the intake manifold is a "Performer 350 Olds." Some sort of edlebrock carb.
That being said, the oil fill tube looks more like one that would be on a 327. I also don't know if the valve cover bolts are normally offset on a 350?
Anywho, here is a low quality picture. I can take different views or whatever may help.
markreed is offline   Reply With Quote
Old 07-16-2012, 11:06 PM   #2
joedoh
joedoh's Avatar
Re: What engine is this?
olds 260 or variant.
edit: the edelbrock page says it will fit olds 307/350/403, judging by the air cleaner its probably a 307 olds. my 79 cutlass had a 260 that looked exactly the same and I dont know why the edlebrock intake wouldnt fit a 260 but maybe it doesnt.
Old 07-17-2012, 01:15 AM   #3
Captainfab
60-66 Nut
Basically your truck has an Oldsmobile engine and trans in it. As for determining exactly what size it is, I do not know. I'm sure someone that does will chime in.
Old 07-17-2012, 02:22 AM   #4
Rich 5150 69
Rich 5150 69's Avatar
You may try here, there are several sites dedicated to olds..
http://www.442.com/oldsfaq/ofblk.htm
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 07-17-2012, 09:38 AM   #5
koda360
koda360's Avatar
That huge intake is screamin OLDS...
1960 C-10
2000 Dakota R/T
1966 Fury I 2dr post
1984 Big Bronco
2002 Durango SLT (Bride's Ride)
koda360 is offline   Reply With Quote
Old 07-17-2012, 09:52 AM   #6
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: What engine is this?
Quick Identification
The large oil fill tube on the front of the engine, sticking up from the timing chain area, is a dead giveaway that it is an Olds engine. The distributor is found at the back of the block and it does not go through the intake manifold, but right into the block. Also the spark plugs will be above the exhaust manifolds with no need for heat shields. Early pre-68 oil fill tubes had a simple smooth tubular top with a press-on oil fill cap. Late 68-up oil fill tubes have a twist-on cap with correspondingly enhanced tube shape, and an engine unit number stamped into the tube, the first digit of which matches the last digit of the year in which that engine hit the streets well, model year, you know.
YearOne www.yearone.com/ had the best info and tech articles on this stuff, but they recently changed their website and many links have changed or deleted. But some are now re-located here http://www.drivinithome.com/#
under Tech Talk > Vehicle Info and Decoding.
For more info on Oldsmobile Engine Identification click on the links below:
http://oldsjunction.classicoldsmobil...sfaq/ofeng.htm
http://www.442.com/oldsfaq/ofeng.htm
http://www.442.com/oldsfaq/ofhed.htm
http://classicoldsmobile.com/forums/...s-engines.html
http://67-72chevytrucks.com/vboard/s...d.php?t=382583
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 07-17-2012, 10:58 AM   #7
markreed
Thanks for the responses! I will pull the numbers and see what I can find out.
Old 08-13-2012, 01:21 PM   #8
txinliner
txinliner's Avatar
Thumbs up Re: What engine is this?
olds y block
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390
txinliner is offline   Reply With Quote
