bught my msd window switch to use with my nitroius
finally bought my msd window switch yseterday. it is the last piece i needed before i run my powershot on a full pass. i am really excited to see what the bucket will do on a full pass. i wll get back with my results. today is street night at irp so i should have some news if it does not rain.
prevous best time 13.86 (without nitrous) |
Got big-block?
![]() Join Date: Jul 2000
What's a "window switch"?
What does it do for your nitrous system? SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
superchevy. a window switch can be used to turn on and of nitrous silinoids( or any other circuts) at certain rpms. the one i have is made by msd. i am using the window swithch as a sort of rpm limiter for my nitrous. i want my nitrous to come on at 2000 rmp and go off at 6000. this will protect me if the throttle sticks or i break the tires loose and dont shift before 6000. the window switch can acitvate almost anything from notrous to shifts lights, and air shifters. the switch can be used on any type of igniton points or hei. the modules used to set the rpms are sold separately. take a look in summit or jegs in the ignition section they can probably explain it better than i did.
MITCH1914, did you go to the track? What did it run with the nitrous?
13.86 on motor...I see a 13.10's..or better on NOS...
the weather was bad and the track did not open this past tuesday, but everyhting is in place and i will be ready to go next week and i am egar to see what the bucket does with the 125 hp full pull
if i can get good traction i am hoping to knock a full second off of the 13.86. i know it is wishfull thinking but i have heard of it happening. what do you guys think? |
a 100 shot should be good for a full second off....
i'll lrt you guys know the results when i go out next tuesday
RAINING AGAIN TODAY TRACK IS CLOSED. I'LL POST MY NEW TIMES WHEN I CAN GET TO A DRY TRACK. I MIGHT TRY MUNCIE TOMORROW
