07-19-2012, 10:24 AM | #1 |
Lift Kit Question
I have been looking around for lift kits for a 1980 1ton dually and all the kits i find say not for 1ton and the 1ton lifts say will not fit dually? my question is why wont a 3/4 12inch lift fit my 1 ton dually? i read on a few other places that its just the diffrence in payload but im not sure so i need help on this. i wanting to put 11r24.5s and they are 43.9 inches tall
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
07-19-2012, 01:41 PM | #2 |
Re: Lift Kit Question
anything would be helpful.
07-19-2012, 07:16 PM | #3 |
id just make them work itd be worth it in the end
75 c30 silverado drw 454/th400hd d70 soon to have d60 up front 73 c20 custom deluxe sm465 14bff parts truck |
07-19-2012, 10:04 PM | #4 |
I thought about that too but I'm worried about clearance. The biggest lift I can find is 12inches
07-19-2012, 10:40 PM | #5 |
Talk to http://offroaddesign.com/catalog.htm if the lift is made he can get it for you.
07-19-2012, 11:09 PM | #6 | |
07-19-2012, 10:48 PM | #7 |
12 inch lift should be enough to clear. Had a blazed with 12 spring and three inch body and it cleared 44 inch tires good. I believe the only difference with 3/4 and knew tons is the rear springs are 56 and half tons are 52 inch springs. I know the 56 inch springs normally run more but could always move the shackle hanger forward. Unless you gonna still use it for hauling heavy stuff or big trailers. I would think a half ton 12 inch lift would do. Check with 4 wheel parts. Com. Part number 01-312 for front springs. And 01-322 for the rears. They was the cheapiest to order just the springs. Just trying to help out.
07-19-2012, 10:58 PM | #8 | |
07-19-2012, 10:49 PM | #9 |
Blazer not blazed lol
07-19-2012, 11:17 PM | #10 |
They will be 8 inch rear springs and three inch blocks. Anything over 8 inch in back would be custom made I think. The 52 inch rears will be cheaper but they do make them in the 56 too. Try ntwonline.com. they got good prices on complete kits.
07-20-2012, 10:01 AM | #11 |
Emailed a place today to figure out a price and how to make it work. I want to keep 56inch springs but the 12 inch kit only comes in 52. i emailed them about the crossover steering all the suspension lift and brake hoses. everything i need except wheels and tires.(thats undecided) thanks for you help guys
07-21-2012, 09:06 AM | #12 |
I got a 3/4 ton lift on mine. only difference I could tell was the front ubolts were different. no big deal. got spring shop local had some made.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
07-21-2012, 10:10 AM | #13 |
i got a quote from a guy and they dont make a 56inch springs. it was right at 2000+shipping for a 12inch lift. i think im going to do it but i have to get my d60 fixed first
07-21-2012, 10:19 AM | #14 |
Dang 2000 seems high? Is that brake lines and steering and shocks too.? I know the last set of front springs I bought was 320 shipped . And rears should be about the same. Surely steering, shocks and lines don't cost 1300 bucks?
07-21-2012, 10:26 AM | #15 |
Just trying to be helpful but. For front and rear springs minus bushings shipped to me is 747.53. I also got some rear three inch blocks and u bolts for a 14 bolt rear. If you needed them.
07-21-2012, 10:28 AM | #16 |
Yeah 2 grand sounds a little high did he say what brand the springs are?
07-21-2012, 10:44 AM | #17 |
I ve had. Three trucks with superlift springs and always liked them
07-21-2012, 12:04 PM | #18 | |
front u-bolts-#GU37051*******$48 2.5inch rear shackle flip-#GU38013*** $189 6inch rear super shackles-#38002-6*** $130 8inch rear springs-?need 56 inch springs.*** $395/pair rear u-bolts-#17752*** $40 crossover steering dana 60-#GK39GMD6012*** $554 extended brakelines-#GU30013*** $127 tuff country shocks-TCI-61331 *** $154/all four That's the list and prices Posted via Mobile Device
07-21-2012, 12:05 PM | #19 | |
