Steering knuckle scraping?
I'm running stock 15x8 rallys and the lower control arm of the spindle is grinding a little bit. Common issue but I also noticed that the steering knuckle digs into wheel. Is this also a common problem? I bought some cheapo 5/16" wheel spacers for the time being but they won't last. I really don't feel like grinding too much off the knuckle. Any help would be greatly appreciated.
By the way, they are McGaughys 2.5" drop spindles. stock springs |
Re: Steering knuckle scraping?
anything? I'm completely stumped
Are you talking about how drop spindles cause the lower control arm to rub the wheel?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
the steering knuckle where the tie rod end bolts to on the spindle
I had that issue but I believe on mine it was the tierod, there was plenty of meat to grind it where it wouldn't rub.
"Whoever said money can't buy happiness has obviously never seen a speed shop! |
