Please help me ID this cam
Custom grind 3 bolt comp cam for LS motors
meowMEOWmeowMEOW
Re: Please help me ID this cam
Where's the third bolt? Looks like 2bolt to me.
I can only find one cam when I look for that grind #. I can't promise this is exactly what you have, but its the only 3727r/3733r cam I found. Serial # A 6725 Spec Card# 047220 Part # 54-000-11 CAMSHAFT, LS1 CHEVY LS1/GEN III '97-UP Core C54-11H CAMSHAFT BLANK, LS1 1997 UP 5.7 CORVETTE Grind # LS1 3727R /3733R HR113+4 DURATION @ .050 INTAKE 234 ROCKER ARM RATIO VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 246 INTAKE 1.70 VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3520 EXHAUST 1.70 VALVE LIFT INTAKE .598 LOBE LIFT EXHAUST .3610 VALVE LIFT EXHAUST .613 LOBE SEPARATION 113.0 DURATION .006 INTAKE C/L 109.0 TAPPET LIFT INTAKE 283 CAM ADVANCE 4 TAPPET LIFT EXHAUST 295 HYDRAULIC Y VALVE TIMING .050 OVERHEAD CAM N VALVE OPEN INTAKE 8 JOURNAL DIAMETER STD 2.165 VALVE OPEN EXHAUST 60 RECOMMENDED VALVE SPRINGS VALVE CLOSED INTAKE 46 DEPARTMENT P VALVE CLOSED EXHAUST 6 SPC INSTR FOR CUSTOMER
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Thanks BR3W.. Its been a while since I put this cam in and I cant seem to find the spec card. Looking to get a nice converter built for the cam. The pic is the rear end of the cam/block. I may just have to call comp
