Moderator
![]() Join Date: May 2007
72 OEM Posi Carrier
Here is a nice OEM posi carrier from a 72 1/2 ton, 12 bolt rear end. It is a series 3 carrier (had 3.07 gears). It was tested and thoroughly cleaned by a local driveline shop. It was swapped out only because a series 4 carrier was needed for 4.11 gears.
$300 Shipped in the CONUS.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: 72 OEM Posi Carrier
Will it work with my non position rear? Use the same axles?
Posted via Mobile Device |
Oh yeah put me in line on this
![]() Join Date: Oct 2006
Just an FYI for anyone wanting this, you can run a ring gear spacer with a 3 series posi and use the 4.10 and numerically higher gears.
#5 | ||
Moderator
Moderator
Still available. No response from Leroy.
![]() Join Date: Aug 2008
I forget if I need a 4 series or 3 for 3:73's...
67-72 parts collector,…
![]() Join Date: Nov 2002
Richmond makes ring and pinion gears to work on the 3 Series carrier all the way up to 4.56 gears.
(thicker ring gear) Likewise they make a 3.73 set that will work on a 4 Series carrier. http://www.richmondgear.com/07Apdfs/page27.pdf 3.08 49-0068-1 40-13 3 3.42 49-0070-1 41-12 3 3.73 49-0072-1 41-11 3 3.73 49-0280-1 41-11 4 4.10 69-0204-1 41-10 4 4.10 69-0350-1 41-10 3 4.56 69-0206-1 41-9 4 4.56 69-0352-1 41-9 3 4.88 69-0298-1 39-8 4 5.13 69-0300-1 41-8 4 5.38 69-0302-1 43-8 4
#9 | |
![]() Join Date: Jul 2001
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
I guess I should have been more specific. I have an oem 3.73 carrier currently
#11 | |
Oem 3.73 carrier is a 4 series.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 07-30-2012 at 09:48 PM. |
#13 | ||
Moderator
![]() Lolife99 and others chimed in and added great info so I did not think it was necessary for me to respond.
Is this the factory Eaton 12 bolt? If so put me in line
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
#15 |
Moderator
It is. You are up if you want it, thanks.
#16 |
Carpe manana
![]() ![]() Join Date: Dec 2010
I really don't know much but I read that OEM 3.73 12 bolt rears needed a 4-series. If I knew a 3-series would work I would probably take this carrier for use in my K10.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#17 | |
I was incorrect. I found this on the net,... 12-Bolt Truck Rear Info: You have 3.07 gears & a 3-Series Carrier which used OEM 3.40 & numerically lower gears. 4-Series Carriers used OEM 3.73 & numerically higher gears.
#18 | |
Restoration Virgin!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#19 |
![]() Join Date: Mar 2011
Do you still have the gearset as well?
I'll get in line...
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
#20 |
How would u like payment? I'll take it. Thanks
#21 |
I bought the last factory Posi that Leddzepp had. The packaging alone was top notch..
#22 |
Ill get that payment right out to you. Thanks!
#23 |
Paypal sent. Thanks Zepp!!!
#24 |
Received to my house today. Fedex delivered it on Saturday! Looks great. Packaging was stellar! I would highly recommend Leddzepp to anyone wanting to buy something, you will not be disappointed. Thanks again sir.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! Last edited by El Campo; 08-04-2012 at 10:44 PM. |
#25 |
Which companies produce 3:73 posi carriers for our 12 bolt rear ends? I know eaton does but what are all the rest? Sorry to hijack ledzepp!
