07-23-2012, 10:06 PM | #1 |
I can see the dash at nite.
I painted the inside of my dash white. Someone posted the article on how to do it. So I did it, and it worked. I took the gauges out , and painted the area that was a light green color white. Drove it the other nite, and it is really bright. Don't buy those bright bulbs. I used self etching primer first. Painted it with a brush. Be careful don't paint the bulbs.
07-24-2012, 01:58 AM | #2 |
Re: I can see the dash at nite.
I done this and added some ridiculously bright smd led bulbs, safe to say i can see the gauges well enough now.
Posted via Mobile Device Posted via Mobile Device |
07-24-2012, 02:21 AM | #3 |
What type of paint?
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
07-24-2012, 08:29 AM | #4 |
I used Sem self ecthing primer. I bought it at an auto paint store. It is in a can so I sprayed some in a small container then brushed it on. I then used Rust-o-Leum gloss white. You will need some small artist brushes. Put plastic on the floor. You may drop the can, or the brush.
07-24-2012, 09:37 AM | #5 |
78K & 79C Jimmys
it's worth it for sure
cheaper then the LEDs, some are using one of mine is green and still brighter then stock white i think
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
07-24-2012, 09:35 AM | #6 |
07-24-2012, 11:45 AM | #7 |
do you have the link to where you learned this? thanks
07-24-2012, 11:50 AM | #8 |
Here is a high level one.....scroll down a bit.
http://67-72chevytrucks.com/vboard/s...60#post5496360 A more extensive write-up is over on CK5 where I converted my cable speedo to an electronic one. |
07-24-2012, 12:12 PM | #9 |
thank you
07-24-2012, 03:55 PM | #10 |
I have to give this a try because i am getting old.....
07-24-2012, 04:08 PM | #11 |
78K & 79C Jimmys
if you want you can add a second colour and keep the clear too
