Old 07-24-2012, 11:46 PM   #1
davepl
davepl's Avatar
How to disassemble your truck in 185 easy steps
I made a transcript of my notes from disassembly. Not sure if they'll ever prove useful to anyone but me, but thought I'd share them just because they might be a curiosity or entertaining.
I don't claim this is the correct or safe way to do it. This is the approach I undertook based on what was most easily accessible at the time with the assumption that I was going to blow the whole truck apart.
Remove washer bottle and bracket
Remove upper radiator brackets
Remove fan and shroud
Drain coolant
Remove radiator and hoses
Remove hood latch and support
Remove headlights and bezels
Remove headlight rings and buckets
Remove Bumper
Remove bumper side mounts to frame
Remove Grille
Remove Aux Battery Tray
Remove Regulator from aux battery tray
Remove main battery tray
Remove alternator bracket
Remove wiper arms
Remove antenna rod
Remove cowl panel
Remove outer driver side fender
Diconnect connection from battery cable to junction block
Remove relay and park lights from radiator support
Remove AC lines and the 2 grommets
Remove AC evaporator tank
Remove AC condensor
Remove clips from buttom of rad support
Remove radiator support
Remove radiator support corners from radiator support
Remove driver's side inner fender brace
Remove parking brake cable from inner fender
Remove passenger side ground strap from inner fender
Remove inner fenders
Remove AC hose fixture and line clips on pump
Rmove heater hoses and valve
Remove negative battery cable
Remove pump to carb fuel line
Remove power steering lines and clips
Remove power steering pump
Remove fuel pump
Remove AC bracket from pump
Remove AC brackets from engine and exhaust manifold
Remove carrier bearing mount assembly
Remove rear universal joint
Remove front driveshaft
Remove rear driveshaft
Drain engine oil
Disconnect speedometer cable from transmission
Remove exhaust collectors
Remove shift linkage
Unbolt engine stands from frame
Remove distributor cap
Remove spark plug wires
Remove distributor
Remove throttle rod
Disconnect ground straps from rear valve cover bolts
Disconnect vacuum hose at engine for vacuum booster
Disconnect oil pressure gauge line from engine
Remove engine and transmission
Remove all emblems and trim from front fenders
Remove line at bottom of brake distribution block
Remove brake pedal retaining clips and washers
Remove vacuum booster
Remove clips and washers from middle brake pin
Remove cotter pin from lower pin and drive pin out
Remove booster bracket from firewall
Remove shift rod from steering column
Remove rag joint
Remove cowl vent solenoid arm and plastic plate
Remove vcowl vent flap from inside cowl
Disconnect heater control cables on top of heater box
Remove heater box assembly from firewall
Remove cowl vent solenoid from bracket
Remove cowl vent solenoid bracket from firewall
Remove plastic wire channel from cowl
Remove wiper motor arms from motor and cowl
Remove outside mirrors
Remove driver's door panel
Remove window regulators and lock hangles
Remove vent windows
Remove main glass from doors
Remove regulators from doors
Unclip 2 rods from each door latch
Remove latch
Remove pull knob from lock rod
Remove handle rod and armature
Remove door handle
Remove chrome strip from inside of door
Remove Custom Camper emblems from doors
Remove cowl to cab seals
Remove door with hinges still attached to doors
Remove door strikers - count shims
Remove seats
Remove console
Remove sill plates
Remove 2 under-column brackets
Remove 1 under-column strap
Disconnect wiring harnesses from column
Disconnect column to firewall screws
Remove column - put in gear needed to align with hole
Remove carpet
Remove carpet underlay
Disconnect speedo cable from instrument cluster
Disconnect oil pressure line from gauge
Disconnect vacuum gauge line
Disconnect tach harness
Remove instrument cluster
Remove headlight switch
Remove wiper swith
Remove glovebox door
Remove glovebox latch
Remove glovebox liner
Remove radio
Remove AC side vents and pipes
Remove headliner
Remove visors
Remove dome lamp
Remove cargo lamp and switch
Remove fuel tank
Remove dome lamp/fuel sender harness
Remove foam insulation from B-pillar
Remove seat belts
Disconnect harness from heater box relay
Disconnect harness and remove grommet from heater resistor
Remove heater box inside cab
Remove antenna base and grommet
Remove weatherstripping from door entries
Disconnect brake switch
Remove pedal box assembly
Remove door pins and floor dimmer
Disconnect ignition connectors
Disconnect wiper connectors
Pull engine harness back through firewall
Remove relay by fusebox
Disconnect orange-white courtesy harness from fusebox
Remove fusebox
Disconnect cable from e-brake assembly
Remove e-brake assembly
Remove passenger floor vent and solenoid
Remove driver floor vent and pull-handle
Remove wiper motor
Remove accelerator rod bell crank
Remove plastic thing by column hole
Remove firewall padding
Remove jute from dash
Remove dash pad
Remove AC center vent
Remove speaker
Remove accelerator pedal mount studs
Disconnect e-brake and speed
Remove oil gauge line and grommet
Remove brake pedal firewall boot
Remove hubcaps
Remove wheels and tires
Remove rear shocks
Disconnect e-brake cable from frame brackets
Disconnect e-brake cables from rear drums
Remove rear brake hose
Remove leaf springs
Remove rear axle as a unit
Remove front shocks
Remove sway bar
Remove tie rods ends from spindles
Remove front brake hoses
Remove upper and lower ball joint cotter pins
Back ball joint nuts off one or two threads
Break ball joints loose
Compress front springs
Disconnect top ball joint
Disconnect lower ball joint
Remove spindles
Remove centerlink
Remove idler arm
Remove idler arm mount
Remove steering box
Remove pitman arm from steering box
Remove upper control arms
Remove lower control arms
Remove brake and fuel hard lines
Remove body mounts
Remove exhaust system
Remove e-brake cables and brackets
Remove speedometer cable
Remove shift linkage bracket from frame
Remove rear leaf bump stops from frame
Remove trailer hitch
Remove rear bumper
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-25-2012, 06:44 AM   #2
JointTech
JointTech's Avatar
Re: How to disassemble your truck in 185 easy steps
now if you had a picture for each of those you would officially win the internets.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 07-25-2012, 08:34 AM   #3
Jonce
Jonce's Avatar
I counted 186 steps.....(via Excel copy and paste)
Nice list though
__________________________________
1971 GMC Stepside
350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar
Jonce is offline   Reply With Quote
Old 07-25-2012, 08:54 AM   #4
Billett
Billett's Avatar
I say we make it a sticky and whoever happens to be doing a certain step can post up a pic or two
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 07-25-2012, 09:26 AM   #5
AirSpeed
AirSpeed's Avatar
I didn't see "crack open beer and stare at truck" on your list! What about "cuss and kick dog when rusted bolt rounds off and hit knuckles" either. Your list is incomplete!
AirSpeed is offline   Reply With Quote
Old 07-25-2012, 12:38 PM   #6
davepl
davepl's Avatar
This truck was pampered enough that nothing rounded off or broke... even the brake lines came apart, which never happens for me.
I do have about 3 pictures per step, but it'd be impractical to upload here :-)
Old 07-25-2012, 01:02 PM   #7
bgwss
bgwss's Avatar
I know it would be huge post with all the pics but would be cool to see it all together.
1967 custom 351E V6 3/4 long bed
bgwss is offline   Reply With Quote
Old 07-25-2012, 01:27 PM   #8
Billett
Billett's Avatar
do you have them on your PC? If you emailed them I'd be willing to shrink them down to a decent size and post them up under their respective sections. It wouldn't be all at once, but it might keep me busy for a while
Will
2024 Toyota Sienna
