07-25-2012, 11:30 PM | #1 |
Emission exempt Exhaust Manifolds?
Hello
Today I picked up some manifolds I found on CL. The ad claimed they were off a 89 Burb with a 350. But they are a different design then my 87 manifolds and have no A.i.r injection port or O2 sensor fitting. So after some searching I believe they're off a C/K 88-95 engine. So my questions, Will they work on my 87? To me it looks like I'll need a new y-pipe. And why don't they have the emission stuff? Thanks |
07-26-2012, 01:51 AM | #2 |
Re: Emission exempt Exhaust Manifolds?
Most "Air injection tube" manifolds went away when fuel injection came along.
My 87 has the "O2" sensor in the left manifold but I think they switched it to the Y-Pipe after a few years. Desert |
07-26-2012, 02:19 AM | #3 |
My '89 Burb has the O2 in the Y-pipe.
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
07-26-2012, 06:46 PM | #4 |
Ok, so did the 88-95 trucks not have the air injection system? Also you guys think they'll work if I also use a y-pipe from a similar year?
07-26-2012, 10:33 PM | #5 |
78K & 79C Jimmys
my 88 has both
lets see yours my others from 78-79
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
07-27-2012, 09:16 PM | #6 |
Here's the ones I got the other day
07-28-2012, 01:20 PM | #7 |
78K & 79C Jimmys
guess i'd call that log style... seen some (air holes)filled "well" ,not filled new tho
07-30-2012, 06:00 PM | #8 |
So think I could drill & tap the holes for the air injection and o2 sensor? Or remove the entire air system, which worries me. No smog test here for cars older then 1995 but they do a visible inspection for cars newer then 35 years old
07-31-2012, 08:27 AM | #9 | |
78K & 79C Jimmys
if they hook up the same get a set for inspection time
07-31-2012, 10:34 AM | #10 |
Depends on how strict the visual inspection is. I have no emissions equipment on my truck thanks to the previous owner, hell the charcoal can is gone. It passes the visual check just fine. My 92 Honda has no cat and the inspection guy says nothing about that either.
07-31-2012, 09:38 PM | #11 |
Well I guess I hit up the junk yards and look for another set. My truck is mostly stock, and I'd kind of like to keep it that way, for the most part.
08-01-2012, 07:34 AM | #12 |
78K & 79C Jimmys
before you use them, clean out the bumps if they have them
it helps with sound/flow
