Old 07-27-2012, 10:00 PM   #1
'82 steppin
'82 steppin's Avatar
Custom floor sheetmetal
I removed my seat today along with the carpet and I noticed big ugly humps on the floor and when I put the single camaro set on I didnt notice any different in seating so Im up to cutting the floors and make it deep like bowls did anyone ever did this before?
'82 steppin is offline   Reply With Quote
Old 07-27-2012, 10:28 PM   #2
kwin
kwin's Avatar
Re: Custom floor sheetmetal
I have done it and several other members have done it as well. Unfortunately my truck and photos were lost in a fire. If you do a search you can find posts on installing late model seats in a square.
Use a lazer level to mark things out and make sure to re-inforce the floor sections you build.
I would suggest bead rolling the new floor panels to avoid the oilcan effect.
You have to remove one brace per side, that should be re-built and dont forget how this changes the carpet.
Good luck.
Keith
kwin is offline   Reply With Quote
Old 07-27-2012, 10:49 PM   #3
mopar346
I wonder if you could use a Camaro or Chevelle floor pan as a base for the modification?
mopar346 is offline   Reply With Quote
Old 07-28-2012, 12:10 PM   #4
'82 steppin
Ok this just came on my mind I think the humps were made to clear the gas tanks mine has dual tanks
Old 07-28-2012, 12:19 PM   #5
kwin
kwin's Avatar
I believe you are correct, You may have to switch to short box tanks.
Old 07-28-2012, 07:18 PM   #6
'82 steppin
I will just cut the tanks making them smaller
