Can I add custom trim moulding?
Can anyone direct me to some info on adding the upper and lower trim mouldings to a truck that came with none? I want to do the white in the center color scheme (custom deluxe??) but my truck currently is just a plain jane C20 with no trim at all. Looking at getting a custom cab- so it has the holes already. Just wondering if there's a thread or procedure for adding the trim- or links to any threads about custom paint/striping. I have searched but not really found what I am looking for. Thanks.
Re: Can I add custom trim moulding?
If you get an assembly manual they have prints of the measurements for trim holes. I would recommend Mar-K in OKC for trim.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#3 | |
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
goin up your way tomorrow lawnboy to pick up a cab. it is a custom so at least some of the holes are there. just don't know how to locate and drill the holes in the correct locations. lemme know- i wouldn't mind lendin a hand one saturday if ya need help
I should read the forum more often. I hope you got your cab okay. I'm still in the process of moving in. I would be available most Saturday's too if you need a hand. Thanks for offering. I like the sound of the stick on mldgs.
Don't drill holes...Most of the repop trim comes with either the metal clips or the plastic clips with the 2 sided tape...If you replace the 2 sided tape with a quality one on the plastic clips they will hold like cement...You can get your moldings on perfectly straight without the worries of drilling a bunch of holes...I've done both, I prefer the stick on type, they don't take paint off when pressed through the holes to start rust .....and you can get better molding alignment...Just my 2 cents
____ ______//__{\_____ ,/_(O)__/____/_(O)_/ |
