Old 07-29-2012, 02:01 AM   #1
71/454
Turbo Guy
71/454's Avatar
Broken motor mount
Im surprised it took this long to break them to be honest.
Does anyone make a stronger than stock, yet bolt in replacement for our trucks?
The obvious would be to swap it to 73 and up mounts but I don't want to pull the motor.
Also, anyone got an example of a brace they use to hold the motor when it torques? I heard they made factory cables for the big block trucks before they changed the bbc mount style in 72, but I've never seen them.
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
Old 07-29-2012, 08:12 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Broken motor mount
There are a couple of pictures in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=415563
Both ends of the cable bolt to the same place on the drivers side. You can see the loop bracket riveted to the frame and the cable going through it. In the second picture on the passenger side it bolts to the exhaust manifold bolts and goes through the motor mount frame bracket.
LockDoc
Leon
Old 07-29-2012, 12:32 PM   #3
71/454
Turbo Guy
71/454's Avatar
Thanks Lockdoc. I think I'll have to come up with something similar.
Prothane makes mounts but it doesn't say whether they have the integrated locking system for our truck mounts like they do for the 69 Camaro type ones. I don't think anybody sells prothane up here anyway so it'll prob be stockers with a brace
12 bolt diff
Old 07-29-2012, 02:18 PM   #4
MusicMan70
MusicMan70's Avatar
Hey There 71/454,
The prothanes do interlock in case of breakage; that's what I have on my 70.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
