Old 07-31-2012, 02:40 PM   #1
Hazieview
Building Dreams out of Dimes!
What color is the horn wire coming from the steering column?
I'm trying to hook up my steering wheel horn button to my air horns. However, the air horns need a direct ground to make the relay work which activates the air horns. I need the horn button on the steering wheel to go directly to ground instead of giving a 12v output supply.
Does anyone know what color the horn wire is?
Thanks!
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 07-31-2012, 02:41 PM   #2
frog210
Re: What color is the horn wire coming from the steering column?
mine is green
frog210 is offline   Reply With Quote
Old 07-31-2012, 03:36 PM   #3
foamypirate
foamypirate's Avatar
You could also use a relay to do something like this. The horn 12V wire would be your trigger. This would provide a ground when the relay gets 12V+ from the horn.
http://www.the12volt.com/relays/page1.asp#p2n
foamypirate is offline   Reply With Quote
