Old 08-01-2012, 09:16 PM   #1
kensousa
AC drier direction?
I just bought a new drier for my factory AC Cheyenne in preparation of installing a new condenser and then charging the system.
The drier is marked on one side of the connections with the word "in".
Can someone help me understand which hose goes into the "in" side?
thanks
kensousa is offline   Reply With Quote
Old 08-01-2012, 09:22 PM   #2
Andy4639
Old member
Andy4639's Avatar
Wink Re: AC drier direction?
Typical system.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-01-2012, 09:26 PM   #3
oldspowered67C10
In goes to the condenser, out goes to the expansion valve.
oldspowered67C10 is offline   Reply With Quote
Old 08-01-2012, 09:28 PM   #4
kensousa
That Sir, is a GREAT diagram.
That helps quite a bit.
thanks
Old 08-01-2012, 10:02 PM   #5
Andy4639
Old member
Andy4639's Avatar
Cool Re: AC drier direction?
Your welcome.
Old 08-01-2012, 10:17 PM   #6
oldspowered67C10
That diagram shows a "h-block" style expansion valve and not what GM used back in the day. Only differences are that the low side will not pass through the expansion valve and yours should have a POA valve at the evaporator outlet.
