Old 08-02-2012, 10:41 PM   #1
Lugnutt
Lugnutt's Avatar
Any Classic Aluminum Rims that fit a 72 k10 4x4?
I just got done finding out that an American Eagle #058 15x10 aluminum wheel doesn't fit a stock 72 chev k10. I've looked at other brands of wheels and most of the websites either don't have "list by vehicle" configuration tool or the tool doesn't list any 15" classic aluminum wheels for my year vehicle.
I see a lot of pics of 4x4 trucks similar to mine sporting nice classic wheels so I guess they can be found. Can any of you recommend a "currently available" classic aluminum wheel in 15x10 6 lug 5.5" that would mount sucessfully to my 72?
I would appreciate your input, thanks,
Gary
Lugnutt is offline   Reply With Quote
Old 08-03-2012, 07:14 AM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Any Classic Aluminum Rims that fit a 72 k10 4x4?
I had a set of American Racing Vector wheels for sale for about 10 years. They were 15 x 10 6 lug. Nobody wanted them, and i was selling them cheap too. I ended up scraping them when aluminum prices went up. 15" tire selection is not as plentiful as the bigger sizes.
Good luck in your quest!
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-03-2012, 09:56 PM   #3
T Herder
Try this site, http://www.rimsntires.com, they have a great shop by vehicle tool. Play around with their site, it gives everything from stock sizes, offsets, etc.
Best regards
T Herder is offline   Reply With Quote
Old 08-03-2012, 11:49 PM   #4
Lugnutt
Lugnutt's Avatar
Best regards
That's a great tool, thanks. Trouble is they list the very wheel that I bought... that doen't fit on my truck. The American Eagle wheel #058 does not fit over a stock 1972 Chevy k10 Delco front brake caliper. I talked to the local American Eagle rep and he going to check on another similar looking wheel they make, a #186 to see if it will fit. If it does, they are going to swap them out for no extra cost (the 186's are a newer and the barrel is somewhat different, more expensive than the #058's). Everyone claims I must have installed aftermarket disc's but I've owned the truck since brand new and have never changed my brake system.
I should know by mid next week how things go. I'm hoping to be able to buy an American made wheel, not one made in China like many of them. We'll see.
Thanks again
Old 08-05-2012, 11:06 PM   #5
72chevyk10
I built it
72chevyk10's Avatar
the caliper or the caliper bracket? mine was hitting on the bracket, it came to a corner. i just ground the corner round and it fits my aluminum wheels just fine now
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 08-06-2012, 12:05 PM   #6
Lugnutt
Lugnutt's Avatar
So, I'm not crazy! Someone else has had this issue too, thanks for responding.
Yes, it's the caliper bracket that the wheel barrel jambs-up into. The tire shop also wanted to grind it down to make it fit, but I told them no. I didn't know how much steel it would take to make them fit and I didn't want to ruin or de-face my original parts. How much steel did you have to remove and was it an American Eagle #058 that you were trying to fit?
Old 08-06-2012, 03:14 PM   #7
72chevyk10
I built it
72chevyk10's Avatar
i have the american racing baja 15x8's it wasnt much to grind off at all. i dont know exactly how much i ground off, i just ground it a little at a time till the wheels fit with about 1/8in (+/-) clearance. looking at it it looks like i never did it. i made it look nice and rounded off like what a factory part might look like.
Old 08-07-2012, 08:35 AM   #8
All the classic rims fit. Not sure about anything new. Back in the day we just bought wheels without giving back space/caliper clearance a thought. I was never even asked what vehicle they were going on. I did run a set of 15" wheels on my '71 K/20 and was told beforehand it would require a little grinding on the caliper...no biggy)
Old 08-11-2012, 01:11 PM   #9
Lugnutt
Lugnutt's Avatar
Well, finally got my rims and wheels mounted. Turns out that both American Eagle #058 and #186 require grinding down my front disc brake caliper brackets. You're right, it's no big deal, can't see the grinding, doesn't weaken the bracket much, only took about an hour. I also want to report that both American Eagle and Americas Tire in Cambell were great to work with. This was a big pain in the neck for the tire shop, but they never complained nor charged me additional for mounting and dismounting the wheels as we tried different rims.
Thanks agin for your feedback, I'll send phots when I figure out what's wrong with my photobucket uploading.
Old 08-11-2012, 06:35 PM   #10
69GWC
Good deal glad you got it all worked out, yes get some pictures up for us.
69GWC is offline   Reply With Quote
Old 08-13-2012, 12:24 PM   #11
Lugnutt
Lugnutt's Avatar
[ATTACH][/ATTACH][/ATTACH]
see if these upload
Old 08-13-2012, 01:10 PM   #12
69GWC
Looks good, nice size on there.
Old 08-13-2012, 05:13 PM   #13
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Hope you dont mind....my neck was starting to hurt! Thats a Tuff looking stepside you have! What size tires are you running?
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 08-13-2012, 06:29 PM   #14
Lugnutt
Lugnutt's Avatar
Great, thanks! Now I can pick my chair up off the floor.
When I first got the truck back in 72 I mounted 1200x16.5's. Then the last set I bought 31" 11.50x15's. When I had the body and paint done last year they opend the front wells enough for me to mount 33" 12.50x15's that you see in the pics. I clear the garage door by about 1/2" and is why I left it stock height.
Old 08-13-2012, 06:32 PM   #15
Lugnutt
Lugnutt's Avatar
I bought the American Eagle #058 rims (made in USA) and mounted the Falken Wildpeak A/T's. I'm happy with the looks, the ride, and the quietness of the tires.
