Old 08-05-2012, 08:22 PM   #1
rustbelt
rustbelt's Avatar
Smile Bench Seat Question
Question about replacing the bench seat in my 61 C20 step side. Thinking about replacing it with a more modern day bench or possibly a bucket setup with center storage. I'd like to know what's been tried already and has proven to work without too much modification. I do not have access to a welder but I can drill holes...
So if you would give me your recommendations on what my options are I'd appreciate it.
rustbelt is offline   Reply With Quote
Old 08-05-2012, 08:36 PM   #2
'63GENIII
'63GENIII's Avatar
Re: Bench Seat Question
I swapped out my original for a 1998 chevy 40 / 60 with the fold down center arm rest. I couldn't be happier although it took forever to find the seat. I did have to drill 4 extra holes but the front holes on either side lined up nicely. I dont know if they came with a fold down console and could only imagine how long it would have taken to find if I was looking for that too. This one does not have the built in seat belts like the newer ones. Belts are still attached to the floor.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 08-05-2012, 08:38 PM   #3
LDO
LDO's Avatar
not to hijack but i was looking at the seat in my 66 today. there is a lever on the driver's side but nothing on the right side to aid in sliding back and forth?
LDO is offline   Reply With Quote
Old 08-05-2012, 09:06 PM   #4
'63GENIII
'63GENIII's Avatar
Usually there's only one handle and it is tied to both track mechanisms (with a long rod) thereby allowing the driver to adjust the seat by him / herself. Come to think of it, I've never seen an older bech seat with adjusters on both sides.
Chris
'63 k15 long step
Old 08-05-2012, 09:11 PM   #5
rustbelt
rustbelt's Avatar
Thanks '63GenIII, I can appreciate the time it took to find that 40 / 60 split.
I was I was hoping something like a Silverado bench style could drop in or a bucket set. I have not taken any measurements yet, thought I'd draw on the groups experience. Hey LDO, on my 61, there is a wire that runs from the drivers side adjuster lever, across to the passenger side rail. When the driver makes the adjustment on his side, it pulls the wire to release the spot on the passenger side. Hope this helps.
Old 08-05-2012, 09:38 PM   #6
LDO
LDO's Avatar
sorry, I didn't mean to imply that there should be an adjuster on the pass. side but there should be a mechanism that is actuated by a rod or cable from the driver side. What I meant to say is that there doesn't seem to be a mechanism on the pass. side. Just the track. It slides back and forth but it doesn't lock into position. I'll have to take some pics in the a.m. to get additional input.
Old 08-05-2012, 10:31 PM   #7
Rich 5150 69
Rich 5150 69's Avatar
There is a track lock on the pass side, but there is a rod that operates the right side from the left side......
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 08-05-2012, 09:10 PM   #8
brokenspoke
brokenspoke's Avatar
I used a early to mid 90's Chevy truck seat....the front outer holes lined up...I had to drill 4 holes...It really like the seat
brokenspoke is offline   Reply With Quote
Old 08-05-2012, 09:54 PM   #9
McCoyAZ
McCoyAZ's Avatar
Used some 05 Tahoe bucket seats with the integrated seat belts.
McCoyAZ is offline   Reply With Quote
