Carb Problems
I have a zz4 crate motor with a new edelbrock 600 and have had nothing but problems with it. The carb wants to stumble, has problems starting after motor has been run, and has half the guts than the holly that I replaced it with. Anyone else have this problem?
I have replaced the springs in the carb and put a thicker gasket below the carb. I have searched high and low for a vac. leak but to no avail. I have pulled the PCV valve hose off and it still runs. Put two rags over the carb to choke it and it won't die! Any advice is appreciated... ![]() Posted via Mobile Device |
Re: Carb Problems
what do the sparkplugs look like?
type of gas pum ffuel filter? gas tank and lines clean and freash gas?
Re: Carb Problems
Everything you mentioned is Brand new. Edelbrock suggested the 73x42 metering rods. However, I have tried all of their " kits". Sprayed all over for vac leak and can't find anything....
#4 | |||
"I ain't nobody, dork."
Re: Carb Problems
![]() Gary
Re: Carb Problems
Well Gary, that won't solve my issue with this carb.
#6 | ||
Re: Carb Problems
Very true... but if you have a known good running carb... why keep messing with this one?
Also... what's the ignition system condition? New as well? What's the timing set at? A lot of "carb" issues can atually turn out to be timing/ignition related. Gary
Re: Carb Problems
Those are good carbs. Check the accel. pump shot. They use a leather cup that can dry out from setting. Is the carb flooding after you shut it off? That carb does not like a lot of fuel pressure. About 4-5 lbs. Have you put heavier springs under the metering rods? You may need to change to a smaller metering rod or a larger jet. That engine probably has quite a bit of cam. It may need a quicker spark advance &/or more timing.
Grandpa in the rustmobile...
Re: Carb Problems
Whats the condition of the carb? What is the fuel pressure it sucks if its not @ 5-6psi.
Are the floats set correctly 5.5 is what eddy recomends i think
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Re: Carb Problems
Well, after a long night turning screws, "starting from scratch", the hoopti is running and running without the stumble and hesitation.
Timing is all up to specs according to GM performance. Put the advanced springs and weights in distributor and made some difference. My biggest complaint now is there's no guts behind it anymore, with this carb, the truck is a dog! I am going to put a fuel pressure gauge on it... Will get back shortly Posted via Mobile Device |
#10 | ||
Re: Carb Problems
That could be timing as well... what is the "spec" that GM says needs to be used on the ZZ4? Could also be fuel delivery.
Also as stated above... the Edelbrock carbs don't like much pressure above 5.5 PSI. So shoot for that... you might need a pressure regulator. Gary
Re: Carb Problems
Make sure the secondary throttles are opening. If the choke is not opening all the way it can be blocking the sec. from opening. Or your linkage may not be opening the throttle all the way.
Re: Carb Problems
I have an eddy..it works...(after it was set and regulated).
If I had to do it again Id get a edelbrock fuel pump that puts out the proper psi a fuel regulator is just going to clutter things up. If/When I start driving my truck again ![]()
#13 | |
It'll Buff Out!
![]() Join Date: Apr 2007
Re: Carb Problems
I was not able to prove that, but just thought I would share.
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
