08-06-2012, 04:36 PM | #1 |
A guy with a truck
Narrowed Control Arms
I have been 'bench exploring' some suspension/braking/wheel options and wondering what, if any, negative effects 1" narrowed control arms would have on the supension geometry. I assume that the camber, and therefore caster gain will be more aggressive, but is this necessarily a bad thing? What other possible side-effects (positive or negative) am I overlooking? Any and all input is appreciated
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-06-2012, 05:10 PM | #2 |
Re: Narrowed Control Arms
You could check with Heidts, they offer narrowed A-arms for Camaro, Nova and Chevelle. They would probably be able to tell you any pros/cons between stock/narrow set-ups. Just a thought.
08-06-2012, 05:33 PM | #3 |
what r you doing narrowing conrol arms? Dont you have an LQ4 to install?
08-06-2012, 05:57 PM | #4 | |
A guy with a truck
Haha- yes, that is part of what is motivating these ideas. I can already out-drive the truck with its current power plant; that will quickly become an even bigger issue with more HP on tap. The truck needs suspension/brakes so I don't kill myself, or worse, wreck my truck!
08-06-2012, 05:59 PM | #5 |
67-72 parts collector,…
Have you discussed this with Nate?
I know he make narrower control arms and the 1" forward version that helps center the wheel in the wheel opening. (and helps with caster adjustments). http://67-72chevytrucks.com/vboard/s...d.php?t=537266
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-06-2012 at 06:19 PM. |
08-06-2012, 06:14 PM | #6 |
Was just about to post the same exact thing. Pros-Cons from narrowing .5" compared to 1"?
08-06-2012, 08:29 PM | #7 | |
A guy with a truck
