Old 08-06-2012, 09:07 PM   #1
Bigo Serge
Code p0171 & p0174
Hello fellas,
I'm having trouble figuring out what is causing these codes p0171 & p0174. I have a 2004 lq4 with a 4l80 in my 72 Cheyenne. I have replaced the intake manifold gaskets and could not find any leaks. I'm getting pretty frustrated with my research, so any input would be greatly appreciated. Could it be a weak fuel pump or sticky injector causing this? I have order a new relocating fuel tank with an in tank fuel pump from Boyd's aluminum tanks. Thanks. Sergio
Pick'em up, lay'em down, Oh Yeahhh
Bigo Serge is offline   Reply With Quote
Old 08-06-2012, 10:17 PM   #2
68longhorn
68longhorn's Avatar
Re: Code p0171 & p0174
Yes it could be a weak pump. Do you have a regulator that is set to low? Are the pcv and breather hoses ok? To find a leak spray carb/tb cleaner around the intake and breather hoses and listen for a idle change. If no changes occur I would check fuel pressure. Are you still fuel injected? A faulty sensor could cause these dtc's too.
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 08-06-2012, 11:01 PM   #3
Bigo Serge
My fuel regulator is on the fuel rail, so I'm pretty sure it's ok, I'm running a cold air intake and I tried the intake cleaner spray trick with no idle changes. Yep, fuel injection.
Old 08-07-2012, 01:38 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
both are lean codes
do you have any leaks at the exhaust manifold, before the o2 sensor (would be a false lean condition then)
Otherwise if it is actually running lean, you can check to make sure the injectors are working, that your getting fuel pressure, and if you have done any aftermarket stuff, make sure it was properfly tuned
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-07-2012, 11:50 AM   #5
68longhorn
68longhorn's Avatar
next step would be try a fuel pressure test.
Old 08-07-2012, 01:26 PM   #6
Bigo Serge
Thanks for the input. I'm going to check the exhaust manifolds for leaks, and recheck my regulator, injectors, and pressure. Thanks again I'll keep you guys posted with what I find.
Old 08-07-2012, 01:54 PM   #7
scss02
Make sure the 02 Sensor are on the correct sides. If they are swapped it can cause this problem. Also make sure the ground wires on the back of the motor are secure. And make sure that you do not have cracked exhaust around the 02 sensor. I went through this, it ended up being a loose connection to the injector harness plug.
scss02 is offline   Reply With Quote
Old 08-07-2012, 08:10 PM   #8
clinebarger
Ive seen alot of cracked intakes on wreaking yard pullouts, Usually right behind the throttle body "pad" on the bottom side of the intake.
Alot of the available LS engines were in accidents.
clinebarger is offline   Reply With Quote
Old 08-07-2012, 11:28 PM   #9
Bigo Serge
Thanks Im going to see if I can rent a smoke machine. I'll be surprised if its cracked, since my motor wasn't in a front end collision.
