Old 08-07-2012, 07:28 PM   #1
JGross
Where did you get your 700r4
I'm getting ready to upgrade my TH400 to a 700r4 and I need some advice on where to get an overdrive. I've done some research online and found several sites that have transmitions available, I was leaning toward Bowtie Overdrive but I read their custormer support isn't all that good. My 65 has a stock 350 and is a daily driver so I'm looking for a basic trans any suggestions?
JGross is offline   Reply With Quote
Old 08-07-2012, 07:37 PM   #2
MisterC
MisterC's Avatar
Re: Where did you get your 700r4
Great resource link:
http://67-72chevytrucks.com/vboard/s...ad.php?t=33266
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 08-07-2012, 07:39 PM   #3
64fleetside
Got a local shop to do mine, they even had a core.
64fleetside is offline   Reply With Quote
Old 08-07-2012, 07:48 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
I work with a couple of local shops for my transmission. If you're already running a TH400, I would upgrade to a 4L80E instead of a 700. Is Broadway Transmission still in business in York?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-07-2012, 09:08 PM   #5
JGross
Yes, there's a Broadway Transmission in Red Lion are they good?
Old 08-08-2012, 03:55 AM   #6
scum1
scum1's Avatar
I found mine off local craigslist...freshly rebuilt with receipt, guy just blew his motor in his caprice, and parted the whole vehicle..i guess keep your eyes open..but take others advice on on 4l80e, esp if you plan on pushin some hp, or a fuel injected motor, cuz you can usually get a nice deal on a married powertrain..
scum1 is offline   Reply With Quote
Old 08-08-2012, 08:21 AM   #7
SFTorange
SFTorange's Avatar
I didn't buy a transmission from Bowtie Overdrives, but I did use their TV made easy cable setup. It was a quality product, and I had good experience with their customer service.
I picked up a later (post 1987 I think) 30-spline input shaft core on craigslist and had it rebuilt locally. I'd recommend shopping around as prices can vary a lot.
You wont regret going to overdrive!
The Brown Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=437222
SFTorange is offline   Reply With Quote
Old 08-08-2012, 10:44 AM   #8
vin63
vin63's Avatar
I would talk with them about what you're goals are and what you're currently running. They may have something available for you, or get you going in the right direction. It'll be much easier working with a local shop.
Old 08-08-2012, 12:49 PM   #9
Clyde65
Clyde65's Avatar
also Pheonix Transmissions in Wetherford TX
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-08-2012, 03:48 PM   #10
Turkey
Turkey's Avatar
Try Monster Transmissions in Brooksville, FL. Even if you don't get one from there they have some good info on their website.
Turkey is offline   Reply With Quote
