Right Stall converter??
I know you're supposed to base the stall convert off the CAM. Thats where my problem comes into play. I bought the engine used so i have no cam card or cam sticker, and i have no idea what cam it could be
I do know it is a Comp Cams. And there is a sticker on one valve cover with 10 part numbers and an executive order number(D-279-6) It supposedly is a 383 stroker motor. Ive narrowed it down to about 5 different cams it could possibly be 12-207-2 duration: 255/261 lift: .421/.451 050: 203/212 12-208-2 duration: 265/269 lift: .442/.465 050: 211/221 12-206-2 duration: 260/260 lift: .440/.440 050 212/212 12-210-2 duration: 268/268 lift: .454/.454 050: 218/218 Now this one has a higher lift, so if it was a stroker motor maybe this one?: 12-106-3 duration: 342/342 lift: .447/.447 050: 222/222 Any ideas?? How can find out what cam i have? Are those numbers different enough to make much of difference in choosing stall converters
1967 C10 Long Bed, Soon to have a 350 1997 Chevy 2500 454 BB |
Re: Right Stall converter??
i would probably not go over 3000 on the stall, my cam looks to be bigger than that and that's all i'm running and it works fine
![]() Join Date: Mar 2003
If it is a mildly built 383, my money is on the 210-2 cam (268) With 268 NOT being the lift, but the duration at .050.
Run a heavy duty stock convertor unless your going to romp on it all the time. What's the rear gear ratio?, tire size? |
#4 | ||
"I ain't nobody, dork."
I've got a very snotty cam in my SBC and the stall I have is 2,800.
Gary
I would go on the side of caution and say 2400 to 2600. If you have a low rear gear lean more toward the 2600 side. If you do go with much over a stock stall and you drive in traffic a cooler at least and a cooler with a fan would be a good idea to keep the trans temp down. Also a deeper pan so you can have more fluid[more fluid=more cooling] and a trans temp gauge are not badideas either. Jim
Might just want to stop guessing. It is an unknown used engine. Pull the pan to look at the bottom end, oil pump and verify it is a stroker. Pull the timing gear to verify the cam numbers. Sticker could have come from anywhere.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
It'll Buff Out!
![]() Join Date: Apr 2007
going through this now with my converter, mine is being built or if you call TCI/B&M etc. the more info you can give them the better.
cam duration and lift @.50 truck weight rear gear tire size engine hp @ flywheel what are you doing with it, street/strip, towing. track etc. A long time ago I R&R'd transmissions for a little while and asked the builders a ton of questions. The more info you can give them the better. I have seen plenty of overstalled converters kill the performance of a good engine. I personally don't like to guess. I would verify what I could.
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
My Carbon Footprint
What are you using the rig for? Make sure you know what you are getting into if you are looking at a 3,000 stall on the street.
#9 | ||
Yup... If you're towing and hauling... that 3,000 stall will make a lot of extra heat in the tranny.
Gary
I had a b&m stall that was crap it never impressed me than decided to have one built for my application and what a difference it made. MPC Midwest performance converter
Fuzzy |
Junior Member
![]() Join Date: Mar 2009
I run a 3000 stall behind my 383 with GM hot cam and 3.73 rearend. I have a Bowtie 700r4
And the combo works great. It is a Circle D converter. Posted via Mobile Device |
#12 | |
It'll Buff Out!
I stated before i'm running a 2800 small boss hogg converter with cooler and it works great with my 383 3:73 gear and a split duration lunati cam
specs are lift is 465/488 duration 290/300 |
I dont want to race it or anything like that. I just basically want it to be a cruiser, i dont plan on towing much with it but i'd like to have the capability if need be.
I have pretty good size tires on 15x8 rims. I believe the gear ratio is 4.11 but i eventually want to swap out the rear end with a ford and 3.73 gears unless the 4.11 are better for cruising and overdrive. I want to be able to have pretty decent take off capability but then again i'm not gonna be racing it.
#15 |
With 4:11 or 3:73 you'll have plenty of take off with that 383, they are torque monsters
#16 |
![]() Join Date: May 2007
Any of the cams listed, will be mild in a 383. Your stock converter will work just fine.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
#17 |
What would be considered "stock" I had the old 2 speed power glide but now I'm converting it to a 700r4
#18 |
![]() Join Date: Nov 2010
Call ALL of the converter companys. They know better than anyone. Have ALL of your info and they will tell you what to run.
