flip kit question for 4/6 drop???
ok i bought my kit for my 4/6 drop and the question i am wanting to know do i have to c- notch the frame or can i just cut the orginal bump stomp and put the smaller ones in when i go to do the flip? thanks guys
Re: flip kit question for 4/6 drop???
If you install flip bracket only, then just cut out the bumpstop, if you add drop shackles or remove leafs then yes c-notch it.
You need a BARE MINIMUM of 2in of travel between axle and frame. Once your kit is installed and if you have less than 2in....notch it.
John 82 Chevy Silverado 350ci/TH350 ![]() |
do you have a pic of the flip bracket?
Most flip kits I've seen only drop 5in
I have a 6/7 drop on mine and dont have to run a c-notch Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
These are DJM flip brackets and shock extenders. Recently some guys have been having problems with this brand, I installed 2 sets last year with no problems.
yeah i read up on that forum something to do with they should only be used for show not high performance. i think that i might have bought the wrong kit do a 4/6 drop
