08-11-2012, 10:32 PM | #1 |
LS1 in a 72 Wiring Harness Help Me If You've Done One Before?
I'm just laying out my stand alone harness for my LS. Can anyone tell me the best place to run the wires inside the cab? I don't need anymore holes in the firewall. If you've done a swap before please let me know. Pictures are always appreciated.
Thanks Posted via Mobile Device |
08-12-2012, 09:31 AM | #2 |
Hand Crafted C-10
Re: LS1 in a 72 Wiring Harness Help Me If You've Done One Before?
We have a special area of the board devoted to these swaps...moving you over there.
08-12-2012, 10:00 AM | #3 |
A day late and $1 short...
I am installing a PSI stand alone harness right now and I routed mine into the cab like this...
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
08-12-2012, 12:54 PM | #4 |
same here...used the stock wiring harnes hole in the firewall....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
08-12-2012, 02:32 PM | #5 |
I used the clutch linkage hole and mounted the ECM on the brake support.
Rex |
08-13-2012, 11:48 PM | #6 |
Are you putting the PCM inside the cab, or just a few wires for gauges and ALDL connector?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
08-15-2012, 09:13 PM | #7 |
Bucksss- Where did you get your grommet? I can't find one anywhere and where are you guys mounting your computers?
08-14-2012, 04:47 PM | #8 |
I want everything in the cab and tucked way up. The clutch linkage hole is a good idea. I had it marked for filling but it might finally serve a purpose. Thanks for all your input.
08-15-2012, 09:17 PM | #9 |
My grommet came on the PSI harness. I am currently building a mount that will be in the glove box area.
Tags |
1972, chevy, lsx, wiring harness |
