Old 08-16-2012, 04:37 AM   #1
66fleetsidewarrior
flexplate frustrations
I have a '66 c10 with a 327, two speed powerglide automatic. I am having to tighten some bolts on my flexplate but cannot reach them because the torque converter is in the way. Do I have to drop the transmission to move the torque converter out of the way to reach the bolts or can I simply unbolt the torque converter and access the bolts? I have been hearing both answers and would really prefer not to drop the transmission if I don't have to. Thanks.
66fleetsidewarrior is offline   Reply With Quote
Old 08-16-2012, 04:56 PM   #2
Wrenchbender Ret
Re: flexplate frustrations
I guess you are refering to the bolts that hold the plate to the crankshaft. I have never tightened them that way but if you unbolt the converter it will move back about 1/4 to 1/2 in. You might get a long open end wrench on the bolts.
Wrenchbender Ret is offline   Reply With Quote
Old 08-16-2012, 05:05 PM   #3
66fleetsidewarrior
How have you done it in the past? Would it be easier than what I am doing?
Old 08-16-2012, 06:06 PM   #4
padresag
why would they be loose?. get a trans jack and move it back(trans ) a few inches so that you can get a torque wrench in there so that you do not have the problem again. do it properly. sometimes ther are just not any short cuts
ron
padresag is offline   Reply With Quote
Old 08-16-2012, 06:51 PM   #5
MARTYZ
MARTYZ's Avatar
If your flex plate is loose , my advise would be to pull transmission back and remove and inspect the plate for damage, if it is damaged you will never keep it tight ! I have never heard of tightening without removing trans.
MARTYZ is offline   Reply With Quote
Old 08-17-2012, 12:20 AM   #6
Captainfab
60-66 Nut
I agree.....
Old 08-17-2012, 12:50 AM   #7
DesertCat
DesertCat's Avatar
Originally Posted by Captainfab View Post
I agree.....
And I agree as well. If my flywheel bolts were becoming loose, I would want to find out why and address that problem. Further, those bolts probably should be inspected now and this time I would use some Locktite and torque them just for my own piece of mind.
Better to do a little more now than break down in a bad place and time.
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
