Question about b&m floorshift install
Well i bought me a b&m hammer shift earlier this year to put in my 74.I was gonna have my mechanic install it for me but im getting impatient and want to put it in. Funds are low so cant take it to him right now. I had it mocked up and its seems a bit too low. So how hard is it to install this and what can I do about the height issue. Pics would be a plus.
Re: Question about b&m floorshift install
Not difficult at all, in fact fairly basic in most cases. Not familiar with the hammer but I will assume it is a cable operated shifter. There should be a bracket that mounts to a couple of pan bolts and hook the cable to the tranny shift lever. Find or create a hole for the cable to run through into the cab and mount the shifter to a solid surface and hook up the cable. Should be insrtuction in the box with it, if not should be able to find them on the net somewhere. Adjust it in neutral in most cases and then make sure all the gears click in correctly.
As far as it looking low, it probably is, most floor shifters are designed to be mounted in a car on the tunnel which will set it up higher. I have seen custom boxes or consoles when mounted in trucks but the key is it needs to be mounted solid. I even saw one once mounted in the dash with the face plate and the shift being the only thing sticking out, kinds like and old dash shifter on a van or motorhome. Pretty cool. |
I have one and they are pretty straight forward to install. They make shifters just for trucks that are a little higher , you could just add a taller handle to it .
http://www.jegs.com/p/B-M/B-M-Light-...45755/10002/-1
![]() 1985 C10 2004 Avalanche Last edited by ont_guy_38; 08-17-2012 at 10:29 PM. |
Parts and more parts
I chose the B&M truck megashifter. It comes with a riser setup to get the shifter up to your level. If you insist on the B&M Hammer, then I would suggest getting the riser parts for the Megashifter for trucks and my bet is that it will bolt in easily. The Hammer is designed for cars that have the center hump up between the seats.
Open B&M's website and search for the truck megashifter and get the parts list from that page. You will also need the taller plastic shifter cover to fit the taller bracketry. You could just purchase a B&M truck megashifter and then put your hammer handle on that shift stick.
Frank Last edited by piecesparts; 08-18-2012 at 12:06 AM. |
