08-18-2012, 12:58 PM | #1 |
What to do?
Ok...I fixed the trans. leak by getting a DERALE pan and Moroso blue gasket and LOKAR anchor lock dipstick, but earlier this week I had checked the fluid level and it seemed low so I added a few more fluids into it. Now, I had put too much trans. fluid where it had a slight leak. Do I have to take out the whole pan and clean out the gasket or I just drain 2 qts or so and hope that stops the slight leak w/o removing the pan??? .
- 1967 Chevrolet C/10 SWB fleetside (New Project). - 1969 Chevrolet C/10 SWB fleetside (SOLD) - 2000 Ford Mustang 232 (DD) - 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver) |
08-18-2012, 01:01 PM | #2 |
Moderator
Re: What to do?
Are you checking the transmission fluid with the truck warmed up and running?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-18-2012, 01:02 PM | #3 |
Re: What to do?
Only when the truck is warm and not running.
08-18-2012, 01:12 PM | #4 |
Moderator
Re: What to do?
You need to check the fluid level while the truck is running to get an accurate reading.
08-18-2012, 01:31 PM | #5 |
Re: What to do?
Thanks...but what about my question. I drained 2 quarts or so, hoping that I don't have to remove the pan and clean out the Moroso blue gasket (reusable) then install again. I only ran the truck for radiator flush and around the block a couple times. Do you think this will stop the slight leak or I have to remove the whole thing and clean the rubber/steel gasket and reinstall again.
08-18-2012, 06:00 PM | #6 | |
Re: What to do?
08-18-2012, 07:30 PM | #7 |
Re: What to do?
...I hope so. I drained close to 3qts. How much qts does our regular transmission w/ stock pan carry? My Derale pan requires 2+qts.
08-19-2012, 12:16 PM | #8 | |||
"I ain't nobody, dork."
Re: What to do?
The tranny fluid will expand a bit when warm, and also it will be running through the valve body, and torque converter. Gary
08-19-2012, 01:25 AM | #9 |
Re: What to do?
It will eventually leak/ blow out whatever it doesn't need ( and make a huge mess) Ask me how I know!
Posted via Mobile Device |
