Old 08-20-2012, 09:43 PM   #1
frog210
Wiring from 74 headlights to 82 headlights
Hey guys have a new question
I recently did a front clip swap from a 74 to 82 and wanted to ask this...
how do i wire up all four headlights now
before i only had the
2 front headlights
2 front turn signals
2 side turn signals
now i have the four headlights and
2 side turn signals
how exactly do i do this?
frog210 is offline   Reply With Quote
Old 08-20-2012, 09:56 PM   #2
J Knight
J Knight's Avatar
Re: Wiring from 74 headlights to 82 headlights
All you have to do is get two "2 pronged" female head light plugs and jump them from the three pronged low/high beam plug. Connect the ground wire from the two prong plug to the ground wire on the three pronged plug then connect the hot wire from the two pronged plug to the high beam hot wire on the three pronged plug.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 08-20-2012, 10:31 PM   #3
frog210
Do you happen to know which one is the high/low beam at the prong
i tried what you said and the light came on dim
maybe i wired it to the low beam?
Old 08-20-2012, 10:39 PM   #4
J Knight
J Knight's Avatar
Use a test light to determine wich is hot for high then switch to low and test again, the third wire will be the ground.
John
