Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 08-21-2012, 09:46 PM   #1
racingdewman
racingdewman's Avatar
WTB front frame cossmember for rad support
i need a front frame crossmember that supports the lower radiator for a 65 c10 let me know what you have my shipping zip is 13407
racingdewman is offline   Reply With Quote
Old 08-21-2012, 10:32 PM   #2
LT1 Burb
LT1 Burb's Avatar
Re: WTB front frame cossmember for rad support
I have one you can have for 35 plus shipping but it wont have rad hold downs on it
LT1 Burb is offline   Reply With Quote
Old 08-21-2012, 11:07 PM   #3
racingdewman
any chance you would have the piece of frame on pass side just behind this crossmeber were the frame is raised on top for i beleive fuel pump clearance i can get a pic if needed
Old 08-21-2012, 11:52 PM   #4
LT1 Burb
LT1 Burb's Avatar
Yeah, I am cutting up the frame so send me a pic of what you need.
Old 08-22-2012, 09:12 PM   #5
racingdewman
here is a pic of the area i need if i confuse you just ask me to re explain
there are three engine mount holes i need the piece to be at least 1 inch back from the most forward hole and then from there it needs to be 14 inches long total so from the fwd most hole the piece would be 13 inches long you can come down the side of frame min 1 inch that part can be longer whatever you want to do let me know if this is a good description . also do you know if the rad brackets for the frame crossmember can be ordered. would you have a picture of the crossmember i need is it strait i found one local but looks like they hooked a chain to the truck there and bent the crap out of it. thanks hope this is understandable the pice i need should have the raised section of frame on top wich i beleive is clearance for fuel pump
Old 08-22-2012, 09:34 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
That looks like you're missing a portion of the actual frame.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 08-22-2012, 09:53 PM   #7
racingdewman
yea hopefully lt1 burb has the piece i need he said he has a frame he is cutting up.
Old 08-22-2012, 11:09 PM   #8
LT1 Burb
LT1 Burb's Avatar
I have that piece , I will just cut out a section, I also have the rad supports but they are for a small radiator , not a 3 row.
And that is the passenger side, correct.
Old 08-23-2012, 02:09 PM   #9
racingdewman
yes passenger side the peice i need should have the part that sticks up on frame i beleive this is the only part of frame that sticks up above the normal frame
Old 08-23-2012, 10:52 PM   #10
LT1 Burb
LT1 Burb's Avatar
UhOH, my bad, I am confused, I cut from the forward hole 15" back to the cab, did you need it the other way. I can cut it the other way but you will have to make an extra bead now.
Old 08-24-2012, 09:15 AM   #11
racingdewman
yes it needs to be the other way it must have the peice that raises above frame on top ...do you accept paypal let me know what i will owe you thanks
