shaved door kit,,, help
Ok so I bought a shaved door kit for my 82 Chevy custom deluxe 10, so I installed them right
So I close the door and press the button to open the door, but it did not work, so I checked The door latch and I checked the one on my newer 2005 Chevy truck and I saw that my newer truck when I close it and pull the handle without pulling the door towards me it opens up And my 82 I have to pull the handle and pull the door to open it so there is no way that the selenoid will open and push the door out, Is there a solution for this? Posted via Mobile Device |
Re: shaved door kit,,, help
Maybe it needs a stronger solenoid? or
lube the latch and hinges that might help a tiny bit |
It followed me home?
Mount a spring/pusher in the door jamb. I've used a brake spring instead of the little rubber piece on the bottom of the door or you can buy a nicer looking billet pusher
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Old Heap Driver
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
Thanks guyssss!
Parts and more parts
Unless you have something like a "Bearclaw" latch design, you have to use an item called a door popper, to kick the door out.
Frank |
