Leaf Spring Help
Okay so if you put 3/4 ton springs under a 1/2 ton but keeping the 1/2 ton axles, how much will it effect payload wise?
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
Re: Leaf Spring Help
Look up big ten trucks.
The issue with this is you can load more but you can overwork the half ton brakes easily if your not carefull. So upgrade to the bigger brakes as well. Me and my freind did this once, going down hill with 1800#s in the back of scrap steel and we couldn't stop but luckily his suspension was able to get us out of trouble and away from the ditch lol Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Can you put the 3/4 ton brakes on a 1/2 ton axle?
I'd like to put Big Ten or 3/4 ton springs on my 1/2 ton short bed. I will be towing trailers with brakes on them mostly.
Are Big Ten and 3/4 ton springs the same? |
Do not think so. Big 10 or the F44 option made the truck a 5/8 ton. I have the heavy duty springs in the rear of my 1/2 ton and while they are a lot more beefy than the 1/2 ton springs (mine has 8 leafs, standard trucks I think have 4-5) I'm not sure if they are as good as 3/4 ton springs.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
To answer your ignored question yes. Find a 3/4 truck or suburban and they will have the wide brake shoes. You will need to pull your axles and pull your backing plates off. But really if you find a 3/4 ton 10 bolt such as off a suburban they are usually geared better for towing or heavier vehicle weight
Payload is determined by axle as well (ie: bearing capacity).
I have 7+1 springs in my 1/2 ton. (rated at 2900 pounds each). It takes a lot to make the truck squat, but its nice to toss in whatever I want and not have it become a tail dragger. Alex. |
Have you put bigger brakes on the 1/2 ton axles?
Yes my 1/2ton has 4 leafs per side. I will look around and order up some Big Ten springs.
![]() Join Date: Oct 2009
There are light duty 1/2 tons and heavy duty 1/2 tons. There are light duty 3/4 tons and heavy duty 3/4 tons also. Light duty 1/2s have 4 shorter leafs. The hd option is 8 longer leafs which are the same as light duty 3/4 trucks. Even says so in LMC catalog when you look at replacement springs. So the answer to your question is yes. The longer 56" 8 leafs will fit your truck. Both of my c10 shortbeds came stock with the 8 leaf hd springs.
#11 | |
Thanks. |
My 74 c10 shortbed
Has 8 leaf springs on each side So I guess that makes it a hd half ton? I have 12 bolt axle and 5 studs Posted via Mobile Device |
#15 |
If you don't need more than 2700 pounds per spring, you can stay with a 52" leaf, no need to move hangers unless you want the longer leaf spring and 3500 pound capacity.
randomn spring seller; http://www.generalspringkc.com/Leaf_...987_s/1823.htm Alex. Last edited by Axle; 08-29-2012 at 08:44 PM. |
#16 |
Ive owned a 1975 3/4 ton truck and a 1989 3/4 ton suburban. From those and every other 3/4 squarebody truck I have ever seen they had a 14 bolt rear end. Never heard of a 3/4 ton 10 bolt. Since 14 bolt rears are 8 lug, they are completely different than 1/2 ton 5 lugs. I seriously doubt the brakes are interchangeable.
#17 | |
Also the 1-1/4 thick rotors and spindles up front will work great as well. Brake fade from heat is your enemy here. Since with a heavy load+slow speeds that means that the heat does not dissipate. My friends rotors turned blue when we overloaded his. We changed his boiling brake fluid his rotors and pads after that. Posted via Mobile Device
