Old 08-27-2012, 08:53 AM   #1
biohazardbill
Air Ride - Pancake
I have an air ride setup that I would like to install. However after seeing some other rides over the past few weeks, there is one thing that another brand has that mine does not. Pancake. My setup has 3 programmable settings. One would be full up, full down and ride height. The other brand has 3 settings plus pancake.
Is there a way to set up manual switch that will release air from all four bags while still maintaining full functionality of the system? For example the kit also has auto levelling featues so if I let the air out manually would it auto try and refill the bags? I am sure this is what would happen, but wondering if that could be bypassed somehow.
biohazardbill is offline   Reply With Quote
Old 08-27-2012, 12:20 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Air Ride - Pancake
I'm not sure what the difference is between "full down" and "pancake". What exactly are you trying to accomplish? I have 3 settings and they are front up for exiting steep driveways, ride height, and layed out. I don't need another one.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-27-2012, 12:28 PM   #3
biohazardbill
Full down and pancake are the same. Just would like an extra setting and not have to have a programmable one as aired out.
Old 08-27-2012, 12:32 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
wouldn't "full down" be the same as pancake?
All pancake means is dumping all 4 at the same time, which sounds like "Full down" Do you still have individual switches, or is it on the pre-programmed settings only?
If you have individual momentary switches you can wire in an additional switch, with the power wires off the 4 dumping valves.
edit; you said the same thing I said in the first part, I typed too slow.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-27-2012, 04:02 PM   #5
big_al_71
big_al_71's Avatar
My set up has three also i dont see a need for four, up, ride height and aired out.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-27-2012, 04:58 PM   #6
502ms
502ms's Avatar
I have three as well:
1: front up/down
2: rear up/down
3: all up/all down
4: train horn
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 08-27-2012, 11:09 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
I'm still not sure what your wanting, but I can tell you its possible to dump your system with relays. I had four corner control on my last set up with a fifth switch for dump. One relay triggered all of the dump valves and I hit the ground....well stops anyway..
Articles-
"Refining Sierra"
Old 08-27-2012, 11:48 PM   #8
502ms
502ms's Avatar
Full down in my case is pancake...lovely thing is my switches can be toggled to where you want to be...
I think we got him, n2trux
Best Regards,
Leon M.
