Old 09-01-2012, 01:52 PM   #1
tylervalo
Attempting the "$50 paint job"
After reading all the threads on the internet about the $50 paint job using Rustoleum I figured I'd give it a shot. My paint is beat and I wanted it a different color always so what the hell right?
They have a color called "Sand" that's very close to GM Sante Fe tan, which happened to be the color I wanted. Should get started laying down the first layer after lunch.
tylervalo is offline   Reply With Quote
Old 09-01-2012, 02:24 PM   #2
TDS-MN
Re: Attempting the "$50 paint job"
I painted mine with a roller and brush last fall. The slight texture I got was helpful in hiding some of the body imperfections, since my truck had significant rust beforehand. I did sand the rusted areas and apply a brush-on rust converter. I did not thin the paint at all prior to application, which limited it's self-leveling properties. I see that you are spraying the interior and jambs, guessing your plan is to spray exterior as well? Looks like you have a great start.
I was not able to really apply any wax/sealer as I finished my painting the weekend before the winter weather hit last fall. I would suggest soem type of application once your paint cures, I'm probably going to hit mine with another coat here this fall, and hopefully get that done as well. But overall I was surprised at how well the paint held up even thur our harsh winter months here in Minnesota.
EDIT : here's a pic of mine.
http://67-72chevytrucks.com/vboard/s...1&postcount=55
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
Old 09-01-2012, 02:30 PM   #3
tylervalo
No, gonna roll the exterior due to the said self leveling of the paint. I just figured spraying the interior and jams would be easier.
Old 09-01-2012, 02:53 PM   #4
cory d
cory d's Avatar
i have thought about this with my truck. i like sante fe tan, i was going to do cordova brown and a sante fe tan cab top but figured i could do leather brown and white rustolium paint
cory d is offline   Reply With Quote
Old 09-01-2012, 03:02 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
I always use duplicolor. Seems to lay better and doesn't wrinkle itself with multiple coats. Lay down a clear as well so the paint don't oxidize
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-01-2012, 03:04 PM   #6
cory d
cory d's Avatar
i used duplicolor and some rally wheels. i couldnt find argent silver but i got soem "close enough silver" and it worked great. i didnt have any problems with it and it cured up great
Old 09-01-2012, 03:33 PM   #7
BIGTEN
BIGTEN's Avatar
I just sprayed mine this morning with rusto semi-gloss white and it looks good for the first coat. Almost has a pearlish silver thing goin on which makes it look sweet.
BIGTEN is offline   Reply With Quote
Old 09-01-2012, 05:44 PM   #8
JCampbell
Subscribed.
JCampbell is offline   Reply With Quote
Old 09-01-2012, 08:12 PM   #9
tylervalo
Made a mistake on the first coat..THIN THIN THIN! The paint needs to be milky in consistency, any thicker and you get tiny air bubbles.
First Coat:
Second Coat:
Full Second coated:
Gonna get up early tomorrow to wet sand and apply the 3rd and 4th coats.
Old 09-01-2012, 08:22 PM   #10
frog210
What do your neighbors think about all this lol
bet you they have some questions.]
frog210 is offline   Reply With Quote
Old 09-01-2012, 08:51 PM   #11
rustbelt
rustbelt's Avatar
What are you using and what mix ratio are you using to thin out the paint?
rustbelt is offline   Reply With Quote
Old 09-02-2012, 02:30 AM   #12
tylervalo
Haha! Im sorta the young guy in the subdivision, prolly by 10yrs at least. I'm sure they thing Im just some crazy kid.
started out at 75/25, ended up at 50/50.
Old 09-02-2012, 10:32 AM   #13
Corts60
Just here to tinker
Corts60's Avatar
Ha! Awesome. If you check the thread in my sig for my 78, I also used home depot's sand color for my cab. It is very close to the factory buckskin color.
Old 09-01-2012, 08:52 PM   #14
str8axle55
Looks good so far, also thinking about htis for my CC, same color also. My friend at work just did his F@rd van, not sure he thined his, def has a texture, a little to much for me. It kind of reminds me of a refriderator door type texture.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 09-01-2012, 09:45 PM   #15
Firebirdjones
At first I thought you guys were kidding,,,,till I got to post #9
Firebirdjones is offline   Reply With Quote
Old 09-02-2012, 01:33 AM   #16
mongoose
mongoose's Avatar
I started this, this weekend as well... mine went on A LOT thicker than that tho lol...
one coat cover mine pretty well... though I mixed it at 4:1 with xylene, I'll sand it down tomorrow then probably do the other coats 3:1 by weight
shootin' for a 20/20 finish..
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 09-02-2012, 05:42 PM   #17
frog210
You gonna paint it the same color as the post or your gonna paint it that green??
Old 01-20-2014, 04:06 AM   #18
y5mgisi
Second Chance Program
y5mgisi's Avatar
Just have to throw this out there. You can go to this paintforcars.com site, and get a gallon of actual urathane automotive paint, with the reducer/hardener as a package for about $80. Add in the cheap harbor freight paint gun and i think you can get acceptable results with alot less sanding and only a few more dollars.
http://www.paintforcars.com/acrylic_...aint_kits.html
Im considering getting this one,
For when i paint my 78,
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 09-02-2012, 10:46 AM   #19
kylep
kylep's Avatar
i did this on my truck and boy what a ton of sanding. i have never sanded like that in my life. probably spent 2 weeks sanding so i only did one cycle turned out pretty good
2001 Tahoe
1978 K30
kylep is offline   Reply With Quote
Old 09-02-2012, 12:08 PM   #20
tylervalo
You ain't kidding! To anyone else trying, remember THIN THIN THIN!!!!! This morning I had to go sand down the bubbles...every bubble on the whole truck! I almost said F* it today. The 50/50 mix seems ideal, it laid down nice and smooth today:
FYI: The hood has a ton of hail damage so I'm skipping it until I find better hood, and the bottom part of the truck will be Dupont bed liner
Old 09-02-2012, 08:40 PM   #21
mongoose
mongoose's Avatar
its green... tho it's a bit darker than what it seems like there..
Old 09-02-2012, 08:47 PM   #22
tylervalo
Wow, this is coat 4 and it's really starting to take shape:
There are still some thin spots, tomorrow morning I need to finish coat 4 (it rained shortly pretty heavily during coat 4, NO ILL EFFECTS TO THE PAINT, even though it was wet! This rustoleum is amazing) then wet sand again. I'll keep updating.
Old 09-02-2012, 09:05 PM   #23
mongoose
mongoose's Avatar
how bad is your orange peel? yours look pretty smooth... mines horrible lol
Old 09-02-2012, 09:15 PM   #24
tylervalo
It's actually VERY slight. I found a really good technique of applying, I follow the body lines going vertically, make 2 passes over roughly 2ft area. I can see it self leveling and it leaves no lines.
Old 09-02-2012, 10:13 PM   #25
cjlinkster
cjlinkster's Avatar
What's the recoat time that you are allowing between coats. I have always heard that the window was 30 minutes or then wait 24 hrs. Does mixing the thinner/paint at 50/50 ratio shorten the recoat time between coats?
I am planning on doing the same thing to my truck. I can't afford a $1000 paint job on my work truck. It just needs to be the same color all over.
1984 C20, 454, 4 speed named "Gold Member"
cjlinkster is offline   Reply With Quote
