VA72C10
![]() Join Date: Mar 2008
Project#2 67-72 Restoration's Shop truck
: : Update! Truck is SOLD! Buyer is going airbags! ![]() Fast forward two weeks through fruitless searches on Craigslist, ebay, and here for a truck that fit my wants/needs....and most importantly...budget ![]() I'm looking last night at the truck and my wife sits down next to me. She actually likes it at first glance (which is surprising because she only likes a few of the trucks I really like on here and up until now has only liked "shiny" trucks ![]() She goes through craigslist checking out the other options and comes back to this truck...I call the guy to set a time to look at it this morning...
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 04-07-2013 at 12:53 PM. |
VA72C10
Re: Project#2 67-72 Restoration's Shop truck
So I make the 35 minute drive this morning and get out into a light rain to look at the truck. First thing I see is a rust hole above the driver's window and I almost turned and walked away...but decided to look it over more. Next is a swiss-cheese front typical of 67 hoods...and I'm 99% leaving...
![]() For some reason I just really like the truck. It has a cool vibe to it. The interior has a little patina and I plan to leave it that way (minus the privacy curtain, wood dome light/map light combo, and two speakerless speaker mounts ![]() The exterior has a great patina to the white roof and the faded/oxidized red paint. And it's a true 67 small window swb stepside with stock steelies... The bad: Rust over the windshield and driver's door. Crease in driver's door from over-opening caused door skin to separate at top (easy fix-not rusty) Passenger door bottom is gone Rocker patch needed on driver's side big patch needed on passenger side door bottom inner/outer NO engine or transmission set up for 3ott and I have an auto to go in it Windshield cracked and foggy Rusty front hood edge Rusty fender cups Small dry rotted tires No exhaust No radiator No battery Hacked wiring rusty brake lines Original (tired) suspension cracked dash pad cracked seat vinyl (good foam though and a nice cover I can sell) Rusty rad support Rusty inner fenders dented grill dented hood Lots of extra screw holes inside and out... antenna (hole)on back of cab (I have an idea for this) PO sprayed black primer at all rusty areas then some bright orange marking paint (today obviously) as it was wet and running... Parked since 1994
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 10-16-2012 at 01:09 AM. |
VA72C10
Now the good and the overall pictures
Cool patina Step bed is in GREAT shape! Tailgate is solid and clean! Solid floor Solid original floor mat Mostly solid cab supports (one small patch needed that I could see) Inner rockers looked good but I'll check them out better later....but floor is clean at rockers... Solid firewall/kick panels driver's door looks good on bottom Fenders just need cups It's complete...not torn apart correct belts work well Solid foam on the bench (full foam seat) Steelies painted to match I mean come on......it's a 67 short bed stepside small window.... ![]() No hacked radio hole ![]() did I mention cool patina on the interior and exterior? Blank canvas for me Perfect for a shop truck with door logos I have most of the parts for it already Extra parts I can sell (250-350 estimated) $650 delivered to me... ...oh...and cool patina ![]()
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 09-03-2012 at 10:03 PM. |
VA72C10
Now the plans for it...
Install my extra 350/350 combo (or 700r4 if I find a deal asap) Re-wire it with good stock harnesses (I have) Larger tires drop it!!! (have all these parts) drop a-arms with 2" lowering springs in front (now cupped a-arms with bags) front sway bar (stock one I have with new rubber bushings) all new shocks w/ relocators rear bags with schrader valves. drop blocks in rear so I can have more air in rear bags for comfortable ride adj trac bar (went with super trac bar) New wood in bed (patina'd most likely-I'll be using this!) Fix rust paint rust patches to match as closely as possible replace windshield (I have 4 to choose from ![]() scrape stickers off rear window and get sticker residue and orange/black spray paint off og paint... Nice used 67-70 style white front bumper Paint rear bumper white (until I find a deal on a used white step bumper and another hidden hitch) door logos (tbd- coming up with 67-72 restorations logo) caps on the steelies (tbd and open to suggestions) radio delete lighter delete or power outlet for cell phone charger tach dash recovered bench (black or saddle---tbd and open to suggestions) re-done 67 seatbelts better wheel with nice horn cap replace one missing door panel (hope PO finds it...if not I'll be looking...) Finally.... ...drive it and USE it ![]()
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 10-16-2012 at 01:11 AM. |
VA72C10
Options I am considering for down the road or if a deal pops up:
Tilt column (van tilt likely to show this option and it's cheap ![]() A/C (high on the priority list if I get the extra cash or score a killer deal) Hidden hitch behind patina stock stepside sport bumper (if I find deals) considering a 72 front bumper I have tucked in tight with foglights custom in the holes to show those options Buckets and console to show off my work 20" wheels (streeters or 338's in gray) LS motor possible down the road I want to use this as a rolling billboard basically so showing a bunch of custom options is high on my priority list once I get it on the road... NOT painting it ![]() ![]() The only way I'll sell this is A) need the money (sadly this is a distinct possibility because of my constantly fluctuating income) B) find an amazing deal on a 67 crew cab project My ultimate Plan and my goal is to keep this as a parts hauler and also do a crew cab (shiny/custom/LS/show truck) as my future daily driver...but 1st things first....back to my build thread Project #1 ![]()
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 09-03-2012 at 10:36 PM. |
![]() Join Date: Jun 2011
Subscribed!! Cool project
Posted via Mobile Device |
![]() Join Date: Jan 2012
look forward to seeing more of this one too, i have an idea for it if your interested
I love a new project...very cool!
=MATTHEW 69 Stepper...Stroked & Bagged ![]() 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
#9 | |
VA72C10
Thanks! I think it's cool!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Diggin it I sure have turned to love these patina'd trucks. subbed as always
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
pm recieved and replied
It looks like a fun truck to build as a rolling billboard. I'll be following along. Good luck!
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need |
![]() Join Date: Dec 2006
Subscribed, sounds like an awesome project
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
VA72C10
Thanks all! Looking forward to getting it home!
#15 |
thats a sweet deal. sucks about the cab being rusty in those areas but at least its not around the small window area right?
#16 | |
VA72C10
![]() I'm changing a complete roof on my main project and I will use the good section of that cab as patches for this project. Hope to have it delivered Thursday according to the po Posted via Mobile Device
#17 |
Changing the whole upper roof section on mine was a blast! It wasn't bad at all..
-Rus |
#18 | |
VA72C10
![]() Posted via Mobile Device
#19 | |
-Rus |
#20 | |
VA72C10
![]() Thanks, I think it's going to be very cool! Glad you're subscribed! Thanks for always offering to help as well and offering up/having cool parts! ![]() Yeah, I asked him before I took it on...he has done a couple of his own trucks and he's rebuilt several totalled scionxb's by taking a good front and a good back and making one good out of two totals...they look perfect when done and dmv approves them for resale so I figure if he can do that...he can handle a roof swap ![]()
#21 |
[/QUOTE]
Yeah, I asked him before I took it on...he has done a couple of his own trucks and he's rebuilt several totalled scionxb's by taking a good front and a good back and making one good out of two totals...they look perfect when done and dmv approves them for resale so I figure if he can do that...he can handle a roof swap ![]() Lol yeah he should defiantly know how to swap out the roof!
-Rus |
#22 |
Scooped up another one! Love it! I saw it on CL too. As you know from my many mistaken emails I'm always creaping around on there. I like steppers and it seemed like a great deal for what it was.
Sorry I couldn't tell you yes immediately earlier. I need to figure out this towing thing with the new truck. I don't know class I from class III but it looks like I'm going to have to switch to a real reciever before I pull anything. I think it still may be possible to pull a dolly but I'm not sure.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
#23 |
![]() Join Date: Mar 2010
I like it !!!
Should be a cool shop truck.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
#24 |
I will keep an eye on this build 4 sure
#25 |
I know a cool way to do the old patina wood for the bed, I did it to a old 54 chevy truck years ago.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=531265 72 Cheyenne Super 90 Z71 S.B. 434 C.I. Stroker 78 Camaro Z28 (gave to wife she is restoring it) |
