09-04-2012, 12:47 AM | #1 |
Need new tire info - size options
I know there are probably tons of threads about this already, but finding them has proven time consuming on phone lol.
1988 V10 Burb, current tires are getting weather-checked and I am starting to plan for the upcoming tire expenses. It currently has 29.5in tires on it, I need to post tire sizes, but I want to know what size tires it will clear before needing mods? Also, how much will the increased tire size affect mpgs? Posted via Mobile Device
"I just don't think my Suburban Has much to do with climate change, oh woah, Has much to do with climate change and my mind you cannot change..." Tim Hawkins - Free Bird Parody |
09-04-2012, 01:20 AM | #2 |
Re: Need new tire info - size options
when I first got my 2wd burn it had 31 on the back. my dad also has a 90 k5 that has 33s at factory height if I remember right. a friend of mine is also runnin 31 on his 77 k10 believe it's factory height too. hope this helps
Money<Time+Trucks |
09-04-2012, 01:38 AM | #3 |
Carney - thanks that actually helps quite a bit as I was debating on whether or not to try 33s
09-04-2012, 07:51 AM | #4 |
BAD BOW-Silverado XST
Here is a general tire table: http://coloradok5.com/tirefitmenttable.shtml
09-04-2012, 09:21 AM | #5 |
Since you have a 4wd,on 8" wheels you can fit 11.50/32-15s. Those aren't made by many any more,but are the biggest that work w/o a lift. 12.50/33s will work with minimal lift to just the front. I took my '90 Blazer to the spring shop and had them arch and add a leaf for $200. The most commonly run larger size is 10.50/31 and that's the biggest the factory offered. You can go taller and skinnier with 9.50/33 BFGs with no problem.
09-04-2012, 11:20 AM | #6 | ||
