09-06-2012, 10:11 PM | #1 |
^^who I am^^ what I say>
I am about to burn my truck!!!
Hey guys, my most recent project is an 87 CCDRW that i swapped a cummins into, with a 5 speed.
Anyways, the other day I went to town and while I was gone the truck got rained in, when I got in it to drive it the windsheild wipers went about halfway, stopped, and now when I turn on the wipers the blinker indicators light up and the fuel gauge goes to empty. Also, when i turn on the headlights all my gauges go whacko... When I first finished the swap it didnt do this, If I unplug the wipers off the cowl then the lights dont come on the dash. Ive checked all chassis grounds, replaced the ignition switch, tried a different column, nothing works. Please help with any ideas you might have before I go start a bonfire
70 chevy LWB 350/TH350 Barn find (AKA the 70) http://www.67-72chevytrucks.com/vboa...d.php?t=406364 East Tx Squares |
09-06-2012, 10:47 PM | #2 |
Re: I am about to burn my truck!!!
It sounds like a ground issue to me also. If all grounds are good then check every fuse. I have seen the radio and interior lights go crazy when there was a blown horn fuse. Not kidding. The blown fuse caused ground seeking issues. When you pressed the horn button the interior lights would light up.
Don't burn it. Sounds like a cool truck. Frank Posted via Mobile Device
Born and proudly residing in a Red State ! |
09-06-2012, 10:51 PM | #3 |
Thanks frank, glad to see another Texan. I think ill try that tomorrow, makes sense being the truck git rained in.
09-06-2012, 10:58 PM | #4 |
Same check all the grounds
fuses take your cluster apart and let it sit in our TEXAS heat lol maybe it has some water in it
San Antonio, TEXAS -Frog -I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it. |
09-06-2012, 11:15 PM | #5 |
Same happened to mine when water got in the engine and on the fuseblock....Let it dry out and all worked...Only had to replace the wiper switch
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
09-07-2012, 09:03 PM | #6 |
Well, all fuses checked out okay. When I pull the courtesy light fuse, my dash acts normal. Getting frustrated
09-07-2012, 09:51 PM | #7 |
Slots go on anything!
You may still have water somewhere. Since the dome light wiring runs on the floor at the left side, start bychecking there. You probably have a chafed wire there that shorted when it got wet.
1974 Jimmy- 5.3/4L80e/NP241 |
