![]() Join Date: May 2012
71 chevy Paint Schemes?
Anyone have a chart or a link to the Factory Paint schemes they had in 71?
![]() Join Date: Oct 2009
Re: 71 chevy Paint Schemes?
First pic below is of the available colors.
- paint schemes were as follows (not all the trucks are necessarily 71's but these schemes were available in 71): pic 2) solid color all over pic 3) color "a" top over color "b" solid body pic 4) color "a" top over upper body color "b" over color "a" below lower side trim (my fave....) and last but not least, the iconic 71-72 2-tone: color "a" top over color "b" above the upper belt and below the lower side trim with color "a" in the middle - alternating 2-tone. Note that color "a" was not always white (but usually was) - for instance, med olive over yellow was one possible color combo as was the 2 shades of olive together. Hope this helps. |
Thank you sir this most certainly dose now that first truck pic the green one which green would that be?
Should be code 506 dark olive poly
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
black sheep speak da truth
The pic# 4 wasn't available in 71 or 72. That was the deluxe two tone in 69 and 70. The deluxe two tone in 71 and 72 was in between the upper and lower moldings and was not available before 71.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
i always thought that as well - but here's a pic from the 1971 sales brochure.
So, I dunno - I haven't seen many (or any?) like that - but SURELY the brochure can't be wrong!!! (I'm being sarcastic, they often are - or plans change before production sometimes). This was, however, a new pic in 71, not a reprint 70 pic with the new grille stuffed in (i have seen that done on a couple of the small sales brochure pics in subsequent year offerings - i.e. 71 grille pasted onto a 70 truck pic - this was done on the 71 camper/rec vehicle brochure a few times as a matter of fact). Having said all that - I'm not inclined to disagree with you - would not be surprised if the only ones like this were indeed just in the brochure. Maybe someone has a live example? |
Weird! I've never seen that brochure, and at first glance it does appear to be a new '71.. but the lack of an engine designation under the marker and what appears to be one under the custom emblem leads me to believe that this is in fact a re-touched '70 pic.
#9 | |
67-72 Solid paint 67-72 Conventional Two-Tone... primary color with a white roof, includes separation trim on cab that is not available without Two-Tone paint. 69-72 Custom Two-Tone... primary color with a white roof and white below the lower body moldings. 71-72 Deluxe Two-Tone... primary color with a white roof and white between the upper/belt and lower body moldings. As noted white was generally the secondary color on Two-Tones but other colors were available in specific combinations. However virtually anything could be ordered but would have been a "Special Paint" truck. Generally these are RPO 1001 or 4001.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Now that I think about it, that two-tone combination was available in 71-72, but only on a suburban, not on a pick up. This would explain why its in your book. But that pic iabove is a re-touched 70.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html Last edited by ls1nova71; 09-10-2012 at 03:08 AM. |
#11 | |
The Suburban differs in that Deluxe Two-Tone style was not offered on it. Also Suburbans with the upper and lower secondaries were called Special Two-Tone instead of the pickup's Custom Two-Tone. The Custom Two-Tone was offered from 69-72 on pickups. It was not often seen on pickups when Chevrolet introduced and heavily pushed the Deluxe Two-Tone for the 71MY but they were offered concurrently. The Chevrolet truck brochures are light on the Custom Two-Tone paint but it is in the '71 truck brochure and both the '71 and '72 GMC brochures. Without a doubt the clip that Jocko posted from the '71 truck brochure may show an altered '70 or a pre-production face lift '71. The often have features that differ from final production. But generally they are close and often revised.
One of the First
![]() Join Date: Jan 2000
On a side bar: a OE '71 outer front grill had a painted black band aroung the edges. 72 did not, just plane chrome plating. I'll try and find a picture of a 71-72 outer grills.
Ah, in the brochure...
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
