09-08-2012, 11:30 PM | #1 |
Drive shaft support bearing question
72 lwb I'm trying to resurrect. I was under the truck at the back of the transmission and pushed up on the drive shaft. It moves a 1/2" or better up and down in the support bearing housing. Time for a new bearing - right?
Thanks, Bob Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
09-08-2012, 11:34 PM | #2 |
Re: Drive shaft support bearing question
Sounds bad to me.
09-09-2012, 12:03 AM | #3 |
This is probably the easiest and cheapest thing to try first.
http://www.napaonline.com/Catalog/Ca...087_0065479592 In Posts #72 thru 74 of my Project thread I relate my experience with this thing.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
09-09-2012, 10:55 AM | #4 |
Thanks Jim! Lots of good information and how to you posted for us!
Bob Posted via Mobile Device Posted via Mobile Device |
09-09-2012, 11:23 AM | #5 |
Bob, been thru this just get a good bearing, the cheap ones last about 6 months, beausethe mounting backet is only tack welded in a couple spots, if you can get a SKF bearing there made in canada and spot welded in 8 places and welded down the sides great bearing hav'nt a probelm since i installed it, should run you about 40-45 bucks.
