09-11-2012, 12:02 PM | #1 |
E.H.F.D Engine #2
WTB: 71/72 Gas pedal and bracket
Looking for a 71/72 gas pedal and bracket in good shape. Need one with the pedal still attached, not just the rod. Throttle cable would be a plus too. For a small block with a manual, so no kickdown switch needed.
Let me know what you have, thanks!
-NICK '72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation '89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205 '15 Chevy 2500HD CCSB High Country Duramax '22 Tahoe Premier Duramax |
09-11-2012, 12:53 PM | #2 |
Re: WTB: 71/72 Gas pedal and bracket
Pm sent
Pancho 69 c/10 step side 454/400 with 3.07 |
09-11-2012, 02:04 PM | #3 |
Always on the hunt...
I have the setup available with a good accelerator cable as requested for $40., if interested in options/extra add ons, I also have this same type throttle cable/pedal setup with the optional #K31 manual throttle control available for $125. complete. Cost to get either setup to you would be $12.10 sent USPS priority, can get you pics of each setup if interested. Mel
09-11-2012, 03:16 PM | #4 | |
E.H.F.D Engine #2
09-13-2012, 11:58 PM | #5 | |
For anyone else that may be needing a 71/72 cable type accelerator pedal setup, the 72 setup on the right and the 72 setup still attached to the section of firewall are both avaialble @ $40. & $65. + ship. Also, yfs200p has passed on needing the option #K31 manual throttle setup that I offered above, anybody else looking for this somewhat hard to find option? While going through the storage bins for the below setups, have found one complete 71 style #K31 M/T pedal & cable setup ($125.) and one complete 72 style #K31 M/T pedal & cable setup ($175.) off a BBC/TH400 truck so this setup has the kickdown switch and wiring harness to trans, this TH400 kickdown switch and wiring harness could also be moved over to the 71 M/T pedal setup and the price would then be adjusted by $50. on either setup. Both are now out on the bench so if anyone is interested let me know and I can get some pictures, if any other questions please ask. Mel |
09-14-2012, 12:03 AM | #6 |
More pictures, also if anyone needs one of the below throttle cable to carb brackets shipped with any of the above setups add $10. Mel
09-14-2012, 08:19 AM | #7 |
E.H.F.D Engine #2
Payment sent. Thanks Mel!
09-15-2012, 02:32 AM | #8 |
