09-13-2012, 11:03 AM | #1 |
Gauge problems with 04 Yukon
Anyone had issues with the gauges on thier trucks? I have an 04 Yukon XL K2500 that suddenly spiked the oil pressure and voltmeter.
I had to replace a PCM about 2 months ago, due to it not allowing the alternator to charge. The mechanic that flashed the PCM told me that it was likely caused by a voltage spike, and all I had to do was to sweep the gauges back. I have physically checked oil pressure and voltage, and both are normal. I have tried sweeping the gauges back with a magnet, as well as removing the faceplate and manaully sweeping them back. Magnet did nothing, sweeping them manually makes them work when I start the truck for the first time, but when I shut it off the needles stay, then spike the second time I start it. Truck gives no codes, Kinda at a loss at this point. Any info or advice would be helpful. thanks
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
09-13-2012, 01:49 PM | #2 |
Re: Gauge problems with 04 Yukon
The clutsers are bad about the stepper motors going out
09-13-2012, 01:50 PM | #3 |
