09-14-2012, 12:30 PM | #1 |
Which gears you running?
I have the stock 3.08 with th350 and Im thinking of putting a 3.42 there and keep it highway friendly I had very bad experince with 3.73 with th350 on 25" tires on my Camaro and I dont want to make the same mistake
09-14-2012, 12:43 PM | #2 |
Re: Which gears you running?
3.73 with a th400. 30" tall tire. I'd rather have the 3.08
Posted via Mobile Device |
09-14-2012, 12:51 PM | #3 |
2.56 with a 29" tire (235/75 15) Very "stiff," but otherwise happy with it for general comutining.
09-14-2012, 02:21 PM | #4 |
Should I stick to the stock gears?
09-14-2012, 03:04 PM | #5 |
Well how fast do you want to drive usually and what rpm are you running right now?
09-15-2012, 05:08 AM | #6 | |
09-17-2012, 12:09 PM | #7 | |
i do my burn outs in 4wd |
09-17-2012, 03:33 PM | #8 |
i have a th350 with 3.73 and I just down sized from 305/40/22 to a 275/60/15 the downsize isnt horribly bad, then again its only been 3 days.
I'm gonna drive it for a little while before i decide what route to go tranny wise. I have a comp xe268 with vortec heads.... |
09-14-2012, 03:08 PM | #9 |
3.08 with a 285/50/20. Wound pretty good at 70mph.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
09-14-2012, 05:01 PM | #10 |
Are 373 gears ok on the freeway? I have a 700r4. I am changing gears as well.
09-14-2012, 05:15 PM | #11 |
BAD BOW-Silverado XST
3.73 gears are great for any 28-30" inch tall tire with a 700R4. A stock engine should turn 1800-2200 RPMs at highway speeds.
I run 255/60R15 (27") with 3.08's. 70 MPH = 1950 RPMs. Best MPG 18.5. |
09-14-2012, 06:25 PM | #12 |
350/TH350 with 3.40 gears. At 65 its ok.. I normally drive 55 though.
1979 Sierra Classic Heavy-half 1996 Silverado x-cab "the daily" |
09-14-2012, 08:08 PM | #13 |
how do you find out the gears lol
San Antonio, TEXAS -Frog -I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it. |
09-14-2012, 08:15 PM | #14 |
Look for a tag on one of the rear cover bolts near the top, not a guarantee that it hasn't been changed but a goo chance. With the cover off roll the gear and read the side of it, most have it printed in it. All else falls count the teeth on the ring gear and divide it by the number of teeth on the pinion gear.
Here is a helpful RPM chart that I snagged off of the CJ forum, it is based on 1:1 (none O/D high gear). You can open it to read it, but if anyone knows how to post it, please do. |
09-15-2012, 05:55 AM | #15 |
There is very little reason to have a cam with that operatinig range in a street car much less a truck. I hope oyu have the rest of the components to go with it.
09-15-2012, 06:38 AM | #16 |
383ci internal balance roller block 6" rods Mahle flat top pistons with two valve reliefes
AFR 210cc 2.08/1.60 65cc chamber 80cc exhaust port Victor jr intake 750 street HP Full MSD 1 3/4" hooker long tubes 3600stall on Th350 Trick flow 246/254 .555/.555 on 1.5 rockers (i have the gold 1.6) on 112lsa Moroso oil pan Milodon diamond windage tray Im sure I missed few things here and there Posted via Mobile Device
09-15-2012, 10:16 AM | #17 | |
I run alot of different gears in various cars here, and find 3.73's about perfect for performance and very highway friendly in my opinion. With a 28" tire you can easily cruise at 65 mph at only 2800, and 70 mph isn't much more if you want to make a little time. I daily drive cars like this for years and criss crossed the country a few times. I have cars with... 3.31 and 28" tire 4.10 and 28" tire 3.91 and 26" tire 3.73 and 26" tire 3.73 and 29" tire 4.56 and 28" tire 4.88 and 26" tire 3.73 and 33" tire Only 2 of those listed even have an overdrive trans, and they both have 3.73's. The rest are 1:1. It's all a matter of what you get used to. I find them all to be friendly in their own way Cruising at 65 mph is enough for me 90% of the time so I really don't care if I have an overdrive or not so most any gear works fine for me on the highways. |
09-15-2012, 09:37 AM | #18 |
Junior Member
4.10 gears with sm465 trans & 6.2 diesel on stock 235/85R16 tires. I go everywhere at 55-60.
If it wasn't for the last minute, nothing would ever get done. 1953 3800 - SRW C&C Dump - 216/SM420 1985 K30 Scottsdale - SRW - 6.2/SM465/NP205 (Sold) |
09-15-2012, 10:18 AM | #19 |
I just changed mine from 308 to 342 auto with 255'70 15 tires,I like it ,nice and peppy in town and seems OK on the hiway
09-15-2012, 10:23 AM | #20 | |
I'd have at least bumped that gear to a 3.73 and never thought twice about it. |
09-16-2012, 10:24 AM | #21 |
more peppy than the 3;08 ,s
09-16-2012, 11:13 AM | #22 |
09-17-2012, 10:53 AM | #23 |
09-15-2012, 01:53 PM | #24 | |
The th350 is no good. Look up PATC and find their raptor700r4 run a 3000 stall BUT also have a lockup torque converter and a lock up controller Then add some 373s with a good posi and enjoy your overdrive and hwy mileage Also be sure to run a trans cooler Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
09-15-2012, 02:01 PM | #25 |
Isn't a victor Jr. a dual plane intake? What is the operating range on it?
