09-14-2012, 06:31 PM | #1 |
Key code for door lock?
After having my GPS stolen out of my truck I've decided I do need to be able to lock the doors after all. However the truck only came with an ignition key. Does the door lock or glove lock have the key code(or is there someplace else on the truck) so I can get a new key cut?
09-14-2012, 07:24 PM | #2 | |
Re: Key code for door lock?
i went on Ebay to buy a correct blank so i could have a good spare before i wore out the original.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
09-14-2012, 08:39 PM | #3 | |
Maybe I should see about getting stuff keyed the same. Still need to figure out the original key code though. |
09-14-2012, 10:11 PM | #4 |
Look up Lockdoc here on this site ,he can help you .
09-15-2012, 12:48 AM | #5 |
meowMEOWmeowMEOW
Fwiw, doesn't matter what key you get, you can unlock half of these trucks with a long finger nail. If you really want to keep people out, we forum member need to figure out a BETTER mouse trap than these old door locks. Anyone with a screwdriver doesn't have much stopping them.
Anyone know of a way to put a more modern tumbler in one of these things?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
09-15-2012, 01:41 AM | #6 |
I was going to chime in earlier but stopped myself because i didn't want to be the nay saying wet blanket, but BR3 is right. I had the first truck I restored stolen by a guy who tried the key from HIS truck in MY door, and IT WORKED! In fact, rumor has it if you take a couple dozen or so various Chevy keys with you, you'll get into whatever vintage Chevy you want. The more worn the lock, the less keys you need to try before one fits.
Ultimately, the quality of the door lock isn't that important when a broken window will get you in too. Your best bet is to outsmart the stupid scumbags who steel stuff by using antitheft measures inside like alarms, kill switches, fuel cut-offs, lo jack style tracers, etc., etc. Lots of aftermarket technology to support you here. Man I hate thieves. Good luck. |
09-15-2012, 01:59 AM | #7 |
Senior Enthusiast
I can confirm that rumor/theory. My first car was a 1946 Chevy two door sedan, purchased in 1965. The original ignition switch opened every GM car I ever tried it on. It worked on my 47 Chevy coupe, my dad’s 62 Buick Special, my mom’s 64 Buick Skylark, my 54 Chevy, and a few cars in auto shop that had their keys locked inside.
I thought it was interesting, but having no ill intent the key went with the car when I sold it. After the car was gone I wished I had kept the key just as a novelty item. Years later when I worked at Peterbilt I discovered there were a very limited number of different locks/keys provided for the new trucks. I’m pretty sure the number was 25. So anyone with a Peterbilt key had a 1 in 25 chance of opening any other Pete. Of course that statistic was never published.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
09-15-2012, 12:24 PM | #8 |
take the door handle off--take out the lock--there is a number on it which is the key code. any locksmith can make you a key.
1961 chevy K10 my build is------------61K10 build |
09-15-2012, 03:14 PM | #9 |
09-15-2012, 03:22 PM | #10 | |
I know locksmiths have different tumblers for home door locks when they want to re-key them. I would imagine someone has to have them for autos too. Maybe you can get the ign & door cylinders re-keyed with a non GM type code. That should help, unless the tumbler housing (lock itself) is worn out. I also agree w/ oem4me, having taken some locksmithing classes--for legitimate reasons, the more worn the lock, the easier to pick. Interested to see how this progresses...
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
09-20-2012, 12:34 PM | #11 |
You can take the lock to the dealer or get a new one and they will code it for you, if I were near you and worked at a dealer I would have done it for you
MY ADDICTION STAN THE MAN |
09-20-2012, 03:29 PM | #12 |
True, only five cuts on the key-so 25 different keys sounds about right. I have re-keyed many, you need a plate or frisbee to disassemble them so you don't loose parts, match the key cuts with the tumblers. Not hard at all.
Best prevention against theft? Leave it three on the tree-nobody under 40 can drive one it seems..... |
09-21-2012, 01:30 PM | #13 |
you sure are right on the 3 on the tree. learned on one in a 57 chevy pu. Dad wouldn't tell me and my sis where the gears were. we had to figure it out on our own. drove around in 2nd for awhile till we figured it out. back to the key's---on e-bay there is a guy that will make you a key or key's. I gave him my code--made some key's for me.
09-21-2012, 02:07 PM | #14 |
I'm a locksmith sorry I'm a bit far away to help with this, but if your taking the door lock out to get the key code you might as well take the door lock with you and take your working ignition key so that the locksmith can key your door to match they used the same tumblers from 40 something until about 1995. That way you only have one key when you are done.
A
Link to my 60 http://67-72chevytrucks.com/vboard/s...d.php?t=537517 |
09-23-2012, 11:59 AM | #15 | |
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
02-27-2016, 06:28 PM | #16 |
Looking to get a key made for a 1951 chevy 3100 door lock. never had a key. the code on the cylinder is 9119 or 9.119 Called a lock smith he looked up the code could not find it. Anyone have any info for me would be great. Thanks Mike.
02-27-2016, 11:40 PM | #17 | |
1961 crewcab
http://67-72chevytrucks.com/vboard/s...d.php?t=630654
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
