Old 09-15-2012, 05:20 PM   #1
mjensen
mjensen's Avatar
Ho 52
I have an HO 52 for my truck, but it needs at least a new pinion seal. And when I say it needs a seal, I mean the oil "streams" out of the pinion while the rear end is on jack stands The question is whether or not I should just try to find a pinion seal for this, or try to find another axle. I know the "easy" solution is to find another axle, but if replacing the pinion seal isn't that big of deal, I may just go that route.
Thanks!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 09-15-2012, 05:22 PM   #2
VWBeamer
Re: Ho 52
A good ho can be hard to find...
VWBeamer is offline   Reply With Quote
Old 09-15-2012, 05:34 PM   #3
mjensen
mjensen's Avatar
Re: Ho 52
I was thinking if it's an easy thing to put a pinion seal in then I would just do that. Otherwise I would think about finding me a late model axle. I have no idea how to tell if it's even worth working on at all stuff like backlash and such.
Mike
Old 09-15-2012, 05:36 PM   #4
vectorit
What?
vectorit's Avatar
Re: Ho 52
Rock auto has them.
I did a search for the same seal for my rig, pretty much the same thing as any H052.
http://www.rockauto.com/catalog/raframecatalog.php
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-15-2012, 05:44 PM   #5
mjensen
mjensen's Avatar
Re: Ho 52
I did see that I can get a seal through Rock Auto. In fact that's where I found all my seals for my T221. Place is a great resource for stuff like that. Do you happen to know if the seals are easy to replace, or would it require special tools/ expertise?
Thanks!
Mike
Old 09-16-2012, 02:19 AM   #6
bollybib
bollybib's Avatar
Re: Ho 52
I related my experience with this seal in Posts 28 thru 33 of my Project thread that you may find informative.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 09-16-2012, 11:10 AM   #7
mjensen
mjensen's Avatar
Re: Ho 52
Wow! Great write-up. That doesn't seem so bad. Maybe I'll just replace the seal and keep this rear end.
Mike
Old 09-17-2012, 07:12 AM   #8
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Re: Ho 52
Jim,
I noticed you mentioned the seal number: National 411330N
When I looked that up at Advance auto, it says outer axle seal. Any chance the same seal is used in both locations?
I too have a leaker on my hands lately and I'm in the "talking myself into it" stages of this fix. For some reason, I'm dreding this job...
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
