Old 09-16-2012, 12:07 PM   #1
SunSoaked
SunSoaked's Avatar
Scored a divorced 205 w x-member today
Found my 205 I have been looking for today. Had my choice of a 10 spline input or a divorced setup for $150. The divorced will work much better for what I'm doing. Got lucky in that its still bolted to the factory cross member and its the same width as my K10 frame rails.
I think its out of a late 70s dodge, but I'm trying to figure that out by casting numbers since theres no tag attached. I'm hoping that internally all 205s are pretty much the same. Otherwise, it appears and feels to work just fine.
UPDATE: NP202. Damn!
SunSoaked is offline   Reply With Quote
Old 09-16-2012, 12:24 PM   #2
Redcap
Re: Scored a divorced 205 w x-member today
Doesn't look right for a 205. Shift rail position is strange and no 3-bolt cover inbetween rear output and front output bearing support.
Redcap is offline   Reply With Quote
Old 09-16-2012, 12:34 PM   #3
classicundercar
weird PTO cover too... but it looks New Process and is cast iron?
tag on there?
Current:
1971 K10 lwb
Past:
1972 c10 lwb
1969 c10 swb
1977 c10 lwb
more old jeeps than I want to remember!
classicundercar is offline   Reply With Quote
Old 09-16-2012, 01:55 PM   #4
b454rat
Could be a 200? Not up on other cases. But not a 205, also early 70s possibly late 60s.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 09-16-2012, 02:11 PM   #5
Redcap
Don't think it is a NP200, I had an International with one of those and it looked nothing like the one in OP's picture.
Old 09-16-2012, 05:17 PM   #6
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
That is a International NP202 transfercase.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 09-16-2012, 06:11 PM   #7
SunSoaked
SunSoaked's Avatar
Yep-it is in fact a 202. Lesson learned. I should have been smarter on what I was getting. I trusted the guy knew what he had, he drove up in a highly modified CJ with long travel suspension and Dana 60 hi-pinion axles.
It "looked" right to me, but being a divorced unit, I expected it to look a little different since it didn't have the figure 8 or round bolt pattern.
Well see if the guy makes it right or I tossed away $150.
Old 09-16-2012, 07:54 PM   #8
Chevy1TonFun
Grease Monkey
I'm not sure what the pros and cons are of a NP202, but it might still work for your application. The only things I can think of is parts maybe harder to get. Worst case: If the guy doesn't take it back. Try selling it. Good Luck!
Old 09-16-2012, 10:45 PM   #9
obijuan
if theres nothing wrong with it, run it.
obijuan is offline   Reply With Quote
Old 09-17-2012, 10:24 PM   #10
SunSoaked
SunSoaked's Avatar
The guy took the NP200 back and gave me a good NP205 for $100. He felt bad and didn't know what he had. Anyway, all is good. Going to go thru the 205 and change the input and run it behind my 700r4 until she blows or I find my NV4500/241 or 205 combo.
Old 09-17-2012, 10:30 PM   #11
Chevy1TonFun
Grease Monkey
Glad, it worked out for you.
Old 09-18-2012, 12:03 AM   #12
jbclassix
Junk Yartist
jbclassix's Avatar
Advance Adapters makes an output shaft for the 700r for the 10 spline 205. It requires a factory TH350 to NP205 adapter.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 09-18-2012, 12:34 AM   #13
obijuan
wow thats dirty. GMs corrosion prevention program.
